Question about Sony BRAVIA KDL-46W3000 Television
How do I remove the on-screen labels on top left of screen (ie "HDMI", etc)
    President:
  • Sony Master
  • 1,114 Answers
Menu mode to "Settings" toggle to "Banner" setting is "off" it will still display the input at first power up for 15 sec or so, then off. If you still have a problem with this, post a comment and I will help you further
Posted on Sep 27, 2010
I have a 32in Vizio Smart TV, how do I program it to have a channel 03 so I can hookup an older VCR. I already have a DVD player hooked up to its Red/Yellow/White A/V connectors. Thank you very much for...
If you don't have more entries, you could try to use a SCART switching box. This is one, but there are many others. There are also connectors going from scart to R / W / Y and vice versa.
Mar 15, 2015 | Vizio 32in Class LED Smart TV - VUDU...
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
How can i get google to search in box at top left hand side of screen
Download and install google toolbar. you can access it from here for IE and non-IE(firefox,chrome etc)
please rate me if helpful..
Aug 29, 2011 | Google Computers & Internet
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
How do i get the hdmi working from my acer5536 to my tv
Connect your HDMI cable to laptop then change the setting in audio output to HDMI digital output
For toggling the display you need to press the Fn and F5 together
If you have sounds already playing on the laptop, then you must switch your default to the HDMI then go and re open the program ie itunes. Any other program playing sounds on ur laptop speakers will continue to play through the lap top speakers...
On VISTA do this
Right click your screen
go to personalize
on the left there is an option "connect to a projectror or external display"
Click the speaker picture, and set the default to HDMI by right clicking it and selecting make default.
Close your media programs, and then re-open them and hit play..
Apr 26, 2010 | Acer Aspire 5536-5224 Notebook
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
How do I activate the hdmi inputs on my samsung LE40A656A1FXXU they are in the settings menue but are greyed out ?
Hello John,
What I would like you to do first of all is turn the Power off at the wall to all you Television equipment ie blueray, dvd, sat, etc etc.
What I would like you to do now is connect all your bits and pieces ie your HDMI's to the one's located at the back of your Samsung. once everything is plug in where it should be then I would like you to turn the plug back on to power the lot up.
Now when you look at your HDMI (s) that where Greyed out before will be showen in bright white. What you can do now using your Samsung remote is press MENU then go down to INPUT the arrow along to EDIT NAME then you can label all your bits and pieces whilest The tv is pulled out. This will save you back having to pull this back out to see what HDMI input you have plugged things into.
Hope this sorts you out John, When it does please leave a thumbs up
Cheers
Little Dish Fitter
Oct 06, 2009 | Samsung Televison & Video
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony BRAVIA KDL-46W3000 Television Logo
316 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
