Question about Whirlpool LCR7244H Top Load Washer
I need the wiring schematics for a WHIRLPOOL 7cycle, 2 speed washing machine. Model #: LCR7244HQ. Some of the wires were cut.
I did get it on Whirlpool internet site.
Posted on Dec 03, 2011
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
My dryer is a supreme 7cycle 4temp, model LER7646EZ0. No heat. Is resistance of heater coil around 9omhs? Voltage on one end of heater coil is 52 vac terminal to ground.
Set your meter to "beep" when leads are touched together . Disconnect 1 wire from element , then touch both element terminals . A beep , it's good . Touch the small "thermostat" (thermal cut-off ) terminals at the top of the heater box and see if it beeps . No beep , bad . Pt # 279816 . This pt# includes the thermal cut-off AND the hi-limit thermostat . Both must be replaced .
Jul 29, 2009 | Whirlpool Dryers
Is it possible to take a Whirlpool 3363736 and make a grinder?
I see bench grinders for about ten or twenty dollars at the flea markets all the time. They also have the $$ grinding wheels on them.
May 16, 2009 | Washing Machines
Have a 15 years old KitchenAid Surcare two speed 1/2 hp motor washing machine. part # 3361989 Machine is still working Would however I would like to know what kind of maintenance it needs and how to g
This machine needs no routine maintenance. If it's lasted 15 years, then you have treated it well, not overloading it with too many clothes and putting a strain on it. The tub rusting out may be your biggest worry. The schematic for the electric wiring, the diagram for the machine layout and the tub will be in the owner's manual.
May 14, 2009 | Washing Machines
The agitater has stopped working
Belt needing to be replaced is obvious.
As for a schematic of the motor, I think what you are really needing is a wiring diagram and schematic of the complete washing machine. Most often, there is a paper one glued to the inside of the removable panel on the back of the washing machine. Either there, or inside the control head on the top of the washing machine.
Please include the specific model number in any replies.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle not working
hi
if it is not draining it won't spin right,if it is empting out ok then it can be the solenoid if that model has one, if it has belts check that they are not loose
cheers grant
Nov 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Front Load Washing Machine Model no: AWM8121
hi greg,
you may be right about the incorrect wire connection, since you get no error messages on the LCD display.
go to http://www.servicematters.com/docs/wiring/wiring_main.htm and put in your model #. it will give you the electrical schematic.
you may need a technician for this one, if you don't know how to read a schematic.
Sep 22, 2008 | Whirlpool AWM6120 Front Load Washer
Schematics needed
http://www.searspartsdirect.com/partsdirect/retrieveModelAction!retrieveModelDetails.action?modelNumber=GGW9250PL0&productCategoryId=0151200&brandId=1198&method:retrieveModelDetails=x
This link shows the blow ups for the different area's of the machine. The schematic would just give you a wiring diagram, but if you need that as well, remove the 2 1/4" screws on the top panel towards the rear. Slide the top panel towards the rear and lift up on it. Once the top is out of the way, you should find a schematic on the right hand side panel. If it is not there (as with some duet models), remove the lower front panel (2 1/4" screws along the bottom of the panel) and the schematics will be attached to the inside of the panel itself.
Jul 04, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool LCR7244H Top Load Washer Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
