Tunr on the home stereo system for a minute and then the protect mode comes on and turns off the system
  • 4,234 Answers
See the link below for a generic explanation of protect mode. Please update this with the make and model, and I should be able to priovide you with more specifics regarding common failures and costs.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Sep 27, 2010
    President:
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
When power is turn on in my sony stereo hcdrg77 protect mode comes on
you have a signal short or speaker short somewhere ..check all connections as it detects one somewhere..
Jan 07, 2014 | Audio Players & Recorders
My sony stereo is on protect mode what do i do
Turn volume down, remove speaker wires from back and power on, if protect stays off there is a short in the speaker wire or speaker. But if the protect comes on, the ouput ic is shorted.
Apr 27, 2012 | Audio Players & Recorders
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
After 20-30 minutes work in the USB or AUX mode, the unit turns off. At display panel says PROTECTION. After that this problem (when I turn on) repeats after 3-5 minutes.
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Jan 16, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
PROTECT MODe
reed the users manual...does it say anything about the protect mode ?
Aug 13, 2009 | JVC HX-D7 Shelf System
Protect Unplug
I know that almost all new equipment since 99 or so on up has these. They are too sensitive. This is a system program that will put stereo in protect mode when turned up loud or have a lot of bass on to stop from blowing audio outputs.
Aug 07, 2009 | Sony DAV-DX250 System
No sound
Sometimes, an electronic pulse can cause this protect mode. this can come from an electrical storm or, bad circuitry in the home. Unfortunately, you may have to repackage and send back to the manufacture for repair.
Jan 26, 2009 | Audio Players & Recorders
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
65 people viewed this question
 Grubhead
Grubhead
