Ricoh Aficio MP 161SPF - had paper jam error but no paper jammed, technician found the flag had broken and replaced it. He states when he turned it on it printed faxes in the queue and he made several copies. Upon returning the printer we found the paper tray was stuck, the technician found the stack guide had shifted and was twished upward and at an angle but it took him and hour of sticking hangers etc in the openings to dslodge the green paper stack guide. Once released the printer had an error an error SC-520 Code: 612 410000000 last line or error may have too many zeros. I think he knocked something loose, he is telling me about the possibility its the board or another related issue found in his cross reference manual Any help much appreciated. Dwayne
doc_delphi
  • 11 Answers
SOURCE: CX11NF "Paper Jam" and Noise
Had the same problem, too. The grinding noise came from the gear of the loading mechanism, located (if looked on printer from behind) on the right side next to paper tray.
I had a problem with the paper loading, too.
That problem was due to a broken wire for the magnetic release of the loading mechanism, located on the right side, too.
My experience with this epson is, that most problems with it come from broken wires, e.g. the problems with the ADF I had, the problem with the magnetic release I had.....
If I hadn´t invested so much time and money in this printer, I´d rather scrap it immediately.
Posted on Sep 17, 2008
yooperbud
  • 8637 Answers
SOURCE: HP 5610v states 'paper jam' and there isn't one - how to reset?
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
  • 13433 Answers
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 11, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Posted on Jun 12, 2009
Ricoh Aficio 3228c misfed paper j001. paper jam
This means the machine has been turned on with a jam inside the machine someplace. If you have opened everything in the machine and found nothing then it is time to call a service technician.
Aug 03, 2017 | Ricoh Office Equipment & Supplies
Paper jam on exit sensor MP2000
change the exit sensor or contact one of technicians on
  • Auckland
    Level 2, 60 Stanley Street, Parnell
    P.O. Box 68-024, Newton
    Auckland 1010
    Phone 09 - 374 0701
    Fax 09 - 368 6001
    Email ricohnz@ricoh.co.nz
  • Wellington
    123 Taranaki Street
    P.O. Box 10-258
    Wellington 6011
    Phone 04 - 381 7600
    Fax 04 - 381 7615
    Email wellington@ricoh.co.nz
  • Hamilton
    Cnr Anglesea & London Streets
    P.O. Box 758, Waikato Mail Centre
    Hamilton 3204
    Phone 07 - 957 4500
    Fax 07 - 957 4519
    Email hamilton@ricoh.co.nz
  • pnorth@ricoh.co.nz
    • wellington@ricoh.co.nz
    • christchurch@ricoh.co.nz
    • dunedin@ricoh.co.nz
Mar 10, 2014 | Ricoh Aficio MP 2000 Black and White...
J'ai un ricoh mp 1600 apres un bourage j'ai un message d'ereur sc 559 comment faire
The exit sensor and
the duplex sensor
detect a paper jam 3
times in succession
Paper jams can occur for the following
reasons.
???? Dampness
???? Paper curl
???? Incorrect paper setting in the paper
tray
???? Stripper pawls coming apart
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
Jams when duplexing on ricoh mp161
if you are talking the origanal in the DF check for staples or ppr clips inside the DF, or if it is jaming the copies try fresh ppr clean the rollers.
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
The document wont print and we keep openeing and there is no documnet jammed
You may have a broken switch or paper sensor, that may have happened when the original paper jam was removed
Mar 25, 2010 | Ricoh Aficio MP 2000 Black and White...
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
424 people viewed this question
k24674
jasbo
jasbo
