Question about John Deere Garden
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears to be locked in both directions. Cog wheel at bottom end of steering shaft that engages toothed plate appears to be aligned correctly. Problem appears to be in steering shaft somewhere.
  • Anonymous Mar 31, 2014
    model re130 has excessive vibration and noise from the steering wheel and shaft on startup
    Scholar:
  • 150 Answers
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
  • Sharkwool May 16, 2012
    I have the same issue with l110 j deere. Setting it on fire didn't work but it made me feel better. Now that I replaced all the burnt parts. Besides it being a pain , How can I fix the original stuck steering wheel.
  • Paul Sells
    Paul Sells May 13, 2013
    Place washers under the steering wheel to hold the steering shaft up as high as it will go on the bottom. Make sure the steel bushing groomet extrusion is aligned correctly with the slot. I had to add 3 big washers under my steering wheel.
Does anybody know why steering column doesn't lock on a 5325 john deere tractor?
Its likely worn out.The key switch could be working fine but their is a pin that locks the column spring loaded that maybe worn or damaged or the column tube that receives the pin .
As long as it runs OK and the steering wheel turns its not going to effect anything else but the steering lock .
Oct 28, 2016 | John Deere Garden
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
I have a John Derre L130 and the left steering arm has lots of play any suggestions?
it has a steering wheel not steer arms... your issue is either something is bent/broken, the steering shaft is stripped or the steering wheel is just off
Aug 29, 2014 | John Deere Garden
John deere l130
There's a gear on the end of the steering column that's broken or the roll pin used to hold it on is sheared.
Jul 18, 2013 | Garden
I bought 135A used without the owners manual. He told me I need to greese it, maybe each time I use it. Please help me get a free owner's manual so I don't ruin this machine. I paid 950$ for it.
The only thing that would probably need greasing are the spindles on the front wheels. There should be grease (zerk) fittings on the outside of the wheel axles inside the wheel itself. Not greasing them won't kill your mower. Of course, the manual has ALL the lubrication points listed in a chart in it.
John Deere makes it a little challenging to get a manual, but you have the specs and here is the link. I think you can order a paper version , but this link is to download an electronic version for free. The printed version will cost you.
http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsSearchServlet?tM=HO
Jun 14, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
1,101 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
