Question about Nikon Coolpix 3700 Digital Camera
Hi...my name is nelson, I have got problems with my CP3700, the lenses are always out when I turn it off does not hide the lenses..
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 27, 2010
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 10, 2012 | Hardware & Accessories
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Do you know where I can get the part for my Nelson Tractor sprinkler? It is the black part that holds the sprinkler.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 30, 2011 | Nelson Sprinkler: Traveling Tractor
I can not hide nerwark logo name in main display Problem with the LG GX500 Cell Phone i can not hide nerwark logo name in main display so what can i do for hide netwark logo .
hello aash ashu!
no way to hide the network logo name. but you can disable network if not needed.
feel free to contact me here under your topic if further help is needed.
regards
Feb 26, 2011 | LG GX500 Cell Phone
In samsung corby sometimes am getting call from unknown number. There is no contact in the name of unknown.Still i am receiving as 'Unknown'
Always happens. If there is no saved contact number there will show the number with 'Unknown' name. If you want to save the number with any name, then you might do that and after that if that number calls, it'll show the saved number.
Sometimes there are some incoming call that indicates only 'Unknown' with no number at all or '0000000000' that means callers have chose to hide ID or that is a VOIP call. Many operator permits to hide ID but not all.
Nov 08, 2010 | Samsung Cell Phones
I get error code 63 when i turn on my Fostex vf160
Jan 18, 2010 | Fostex MR16HD/CD Digital Recorder
Parts ideas (online???)
Hi..my name is Keith..and yes..you can get parts for your sprinkler..and im assuming its a L.R.Nelson traveling sprinkler..and you can find the parts online at...www.lrnelsoncorp.stores.yahoo.net
Jul 05, 2009 | Nelson Sprinkler: Traveling Tractor
Lock code for hide folder
1. Click “Start”, “Run,” and then type cmd. When the command prompt opens type “CD C:\Test” (replace “Test” with the name of the folder you want to hide.)
2. Now type “attrib file +s +h” and replace “file” with the name of the actual file name you would like to hide.
3. Now, go back to C:\Test and look for your file or folder, it’s not there! You cannot find it through simply browsing around, through the command prompt, or even if you click “Show Hidden Files and Folders”.
4. To find the folder and it’s contents again simply go back to the command prompt, type “CD C:\Test” (of course, again replacing “Test” with the name of the folder,) and then type “attrib filename -s -h”. You should now be able to find your file again!
Apr 07, 2009 | Intel Computers & Internet
Nikon Coolpix 3700 Digital Camera Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
