Question about Sony VAIO PCV-RZ34G (PCV-RZ34G - EOL) PC Desktop
As soon as i turn my computer on I don't hear a beep anymore. I don't have any monitor display and it won't boot up at all What could be the problem and the solution
  • 644 Answers
There are 2 posibilities:
1. Your power supply has failed, you will need to purchase a new one, but you do ensure you get a reciet of purchase and ask if you can return it if it is not the right one. This way if it boots then great its your power supply, if you still have the problem then its not the power supply and you can take it back to the shop and get your refund.
2. Its *********** board, you should be able to asertain this by using the method above.
Hope this helps.
Posted on Sep 27, 2010
BIOS Update was interrupted. Now laptop won't boot up.
basically your screwed , if the laptop is still under warranty I would return it without telling them u tried to flash the bios....ergo if they find out you will not be covered for warranty
the only other thing you may be able to try is inside of the laptop casing should be a small round battery usually wrapped in heatshrink or alike if you unplug that then unplug power source (main battery) and hold power button down for about 30 sec then replce both batteries and turn on it may reset bios to factory but is highly unlikely!!! you may need to contact the creator of the nios system!!!
Jan 25, 2013 | Intel Lenovo ThinkPad T410 2518F4U 141in...
Tip
Computer beeps
If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
If you try to boot your computer and nothing shows up on your monitor do these steps first.
1-Check all your cables in the back of the computer.
2-check your power source and power cord to the monitor
3-try another monitor if possible
4-If on a power bar try to turn off the power bar and reset the breaker
If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
http://www.michaelstevenstech.com/bios_manufacturer.htm
on Jan 28, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
NO DISPLAY on screen but processor fan is work
If it seems like the computer booted up all the way except the screen is blank.
If so try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok and works, then the video card inside the computer is good, but the original monitor is bad. If the Borrowed monitor does not work, then the video card inside the computer is bad.
If it does not seem like the computer booted up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Jun 09, 2012 | Intel Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Asus p5lp-le no display
If it seems like the computer completed the boot process but the screen is blank, try the steps below.
The problem will either be the monitor or the video card inside the computer. Connect another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad and the video card is good. If the Borrowed monitor does not work then the video card inside the computer is bad.
If the computer did not complete the boot process then try the steps below.
Jun 05, 2012 | ASUS Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
On boot up I can hear the hard drive responding but I dont hear the computer posting and the screen is black.. no errors or anything. Any suggestions?
Reseat the memory and try it again. If it still doesn't work, what do you hear for the hard drive? Does it just whir to a full spin up, or does it chunk n klunk?
Jul 06, 2011 | Toshiba Satellite L305D Notebook
PS3 Display settings issue
Carry out the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
Sony VAIO PCV-RZ34G (PCV-RZ34G - EOL) PC Desktop Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
