Question about Acer X203H bd Monitor
I have this monitor and it became now blank means just white screen i have opened it and first i test the lcd panel on another one its like good then i replaced video mixer ic which named realtek and nothing changed then i suspended on the power board i check its voltage i found them : 4.5 volt and 2.2 volt i am sure that those voltage is not the default voltage so i want 2 know the default voltage i think it may be 12 volt because the filter capacitor on it 35 volt is my think is truth or not??? if any body have the power shematic or diagrame i will be fine thanks 2 all
  • 11,361 Answers
Those voltages does not sound right, it should have 5v for the logic board and 16~20v for the inverter board for this 20" screen size, but you are getting the white screen which means that the backlight is working, so your measurement may be wrong. The white screen means that the T-CON board is not feeding either the 5v or 12v (depend on the screen makes and model) that will be the first palce to check, the logic board supply this voltage through a switched transistor to turn the T-CON board on or off (off during standby mode).
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
I could not locate any free sch for this model yet.
Posted on Sep 28, 2010
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Blank screen with white dash on the bottom
hi
most likely it is a matter of lcd screen.
to be sure, try out the display by connecting to the monitor. if this means there is no problem in your display card working properly. now open the cover of a laptop and looking for connections to LCD screen to the motherboard. If you find it, unplug and plug the back with the tight, then restart your laptop. see the results. if still problems, it forces you to remove the lcd screen laptop computer and do problem solving with LCD cable, inverter and LCD screen. do the test one by one to ensure that the real problem.
Regards.
Feb 22, 2011 | Computers & Internet
So I'm turning on my inspiron 5100 and all i get is a white screen. It sounds like it's on but the screen remains blank white?
Hi Donny,
A white screen usually means the LCD panel has failed/worn out. Here's an easy way to make sure. Get your laptop to an external monitor, whether at your home or a friend's place, and with the laptop off and the external monitor off, connect the monitor video (vga) cable to your laptop. Turn them both on and then on your Dell laptop hold down the fn key down in the bottom left hand corner of the keyboard and press the F8 key up at the top. That transfers the video signal to the external monitor.
If the external monitor shows your laptops normal desktop and icons, then you know for sure the LCD screen on your laptop is worn out. If you get the same white screen on the external monitor, it means the video card/controller on the motherboard of your laptop has worn out and you can move ahead with deciding on repairs or other options.
Good Luck.
PS....if the F8 key doesn't transfer the video signal. look at all the F keys for one that says CRT or one that has a little picture of a monitor to transfer the signal.
Sep 01, 2010 | Dell Inspiron 5100 Notebook
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
White screen comes on when powered on
**Caution. Hazardous voltages inside.
This could be a loose connector inside the monitor connecting the LCD panel. A careful check of these delicate connectors (open, reinsert the cable, close the connector) or remove and reconnect the plugs may fix it. White screen means there is no drive to the LCD panel AT ALL.
Mar 30, 2010 | Proview PL926WBi 19" LCD Monitor
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank Monitor Screen
YOUR POWER SUPPLY GOING TO DROP PLZ TEST YUOR POWER SUPPLY MOSFET
Jan 03, 2008 | Gateway FPD2275W LCD Monitor
Acer X203H bd Monitor Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
