Question about HP LaserJet 5p Printer
Print is garbled with PJL commands
I printed an adobe tax document (form 1120), and on the third page the printer began to have trouble. Since this print, the printer has printed only garbage. I had it networked using a printer hub. I printed directly using a parallel LPT1 port. I used three different computers. I print from DOS, Winodws 2000, and Notepad. Nothing works. The only thing that does not print garbled is the printer test page that is initiated from the printer.
I tried the reset button - no result. How can I reset it back to factory default? Why did this document hose it?
Thanks.
  • agent86fl Jul 15, 2008
    The consensus is the printer needs a formatter.
Unplug printer then plug in again and reboot computer
Posted on Jul 13, 2008
My mac does not send print to the kyocera 7040cdn - rather than print the document I send it prints a whole load of code about the detail in the file - the fonts etc...and takes about 12 mins to print
Typically this kind of behavior when printing indicates that either the print driver is not compatible or corrupt, or the print job contains incompatible PJL commands that the printer cannot interpret. If it worked previously, try printing a different document first as the best first troubleshooting step. If it fails as well, then I would uninstall and reinstall the print driver. Check the manufacturer's website for the current recommended driver.
Sep 05, 2016 | Kyocera Office Equipment & Supplies
Just installed adobe acrobat 6.0. Whenever it try to convert a word file into PDF it says, there is a problem and has to run in 'repair' mode. It then instructs me to restart the computer once it has...
May be your converter is first trying to locate some specific version of Acrobat Reader and then do the conversion and Acrobat 6 might not be the required version.
You can try PDF printer and you just have to do print of any word file and it will print the file and save in form of pdf document
can try one such printer http://www.bullzip.com/products/pdf/info.php
May 17, 2010 | Adobe Acrobat 6.0 Professional for PC
Have downloaded adobe 9.3 but can`t print print pdf forms only header comes out
try printing a word document, if print out is fine, then reinstall the adobe.
Oct 15, 2009 | Computers & Internet
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
LaerJet 5p Extra page prints with code
check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Oct 28, 2008 | HP LaserJet 5p Printer
LaserJet 5p extra page prints first with code
When you get that kind of information those are instructions to the printer. It has been my experience that the drivers loaded for the printer are not the correct ones. Check to make sure that you have the drivers for a HP 5P printer and verify that is what kind a printer you have.
My HP Deskjet printer is getting stoped at the mid of prinintg the paper...
my printer is stopped the work and i want to instal a new free dowmn load what ot do
Jul 18, 2008 | HP DeskJet 3745 Printer
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
Apr 22, 2008 | Lexmark T642 Laser Printer
Trouble printing a thicker form
I have come accross this problem on a number of sites. It may be the Paper Out sensor. It works by emitting light from one half of the sensor reflectiong it of the paer and picking it up with the other half of the sensor. When no paper is present, the light cannot reflect and hense a paper out error is reported. I have seen this error occur when paper with dark backing ( like that for bank and tax forms ) is used.
Aido
Jan 09, 2008 | IBM 6400 Matrix Printer
HP LaserJet 5p Printer Logo
170 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
