Question about Kenmore 62882 Electric Dryer
When I press the Push to start switch the dryer does not stay on unless I manually hold the switch in. I replaced the switch and get the same result.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 28, 2010
When you press the on button nothing happens unless you hold it in what could be causing this
There is a switch on the motor that replace the push to start in the circuit once it gets up to speed. Either it is not reaching speed or the switch has failed.
Eric
Jun 13, 2010 | Hoover HDC6 Electric Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Dryer button will not stay down. When you let go of the dryer button it stops. If I were to stand there and hold the button down it would stay one. While on it clicks
There is a centrifical switch in the motor that will only close once the motor is up to speed, the start button you push energises the starter winding, and once the motor is up to speed the run windings are energised by the centrifical switch.
The switch is not hard to replace but you will need the correct one, take the old one with you unless you'v got the complete model number from the motor.
Aug 14, 2009 | Dryers
Dryer drum won't start unless I manually push start the drum,  then it'll run fine. Turning the start knob just sounds like it want's to start. So right now I have to hold the start button, hold the...
unfortunatly it is either the motor or the drum bearings in the machine. if it is really hard to push i would suggest looking at all the bearings the drum rides on otherwise it is probably the motor that is getting weak.
Jun 08, 2009 | KitchenAid KEYS700LQ Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore 62882 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
