Question about Kenwood DDX7017 Car DVD Player
Kenwood DDX 7039 Region Code 1
I would like to get Region 1 Code for the DDX 7039. Also is there a by-pass code for the parking brake to watch DVD's while in motion? Thanks,
SOURCE: DDX-7039 R-Cam
yes u can, you can connect it to the TV as an EX channel and u can have it ON all time. i did that..
and does not heat up..
Posted on Feb 22, 2008
  • 9 Answers
SOURCE: IS IT POSSIBLE TO UPGRADE DDX 6039 TO DDX 7039?
With this post i presume you are on about in dash monitors!
the DDX6039 and DDX7039 will connect in the same way.
however the remotes are different, the 6039 uses remote rc-dv430 and the 7039 uses an rc dv330.
Posted on Mar 06, 2008
SOURCE: fitting kenwood ddx 5032 do i need to earth the park wire or run
i have the same player in my truck. this is a safty feture of the radio. all yuo have to do is ground the emergency brake wire off the radio. this will by pass the safty for the radio
Posted on Dec 25, 2008
SOURCE: bypass for video on a kenwood ddx-512 car dvd player
jgranados711 is correct. i just shove the green wire into the mounting sleeve. an alligator clip would make it easy. don't get pulled over or crash and die though. :)
Posted on Jul 29, 2009
jose_v17
  • 227 Answers
SOURCE: How do you bypass the parking brake sensor on a
Take the emergency brake wire and hook it to a switch,( they cost like 2 bucks at radio shack) Connect that wire to one end of the switch and the other ground under your dash. When you start it all you have to do is flip that switch on then off and your in business. I have almost always seen everyone mount it on the kicker panel on the left side of the center console. You don't have to conceal the switch but i wouldn't put itt out in plain sight. let me know if we get the problem solved
Posted on Apr 04, 2010
Have a kenwood excelon ddx 7015 forgot password
I would try either an all 0, (ZERO) 1, or 9 code most have a default code for unlocking
Jan 18, 2011 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood ddx712 says parking off when dvd is put in while drivind
This is ok, it is trying to protect you from losing focus on your driving. It is asking for you to pull the parking brake up so that you wont drive while watching a movie, it is against the law to drive while watching TV in a moving vehicle, you must be parked to watch, it is possible to bypass the P-Brake so that you can watch as you drive but it then becomes a technical issue which is too long for me to guide you through here and most car audio shops will not do it for you due to liability reasons if you get into an accident, they dont want to get sued.
Good luck buddy.
Please rate and vote for me if I helped. Thanks.
Jun 13, 2010 | Kenwood DDX-712 Car DVD Player
How to install parking brake wire
on any of the KVT or DDX model kenwood radios, you can just ground the ebrake wire. which will allow you to watch video and have navi functions while driving. just connect it to the black wire of the kenwood or the metal chassis of your dash.
hope this helps
Sep 14, 2009 | Kenwood KVT-514 Car DVD Player
Bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
Apr 09, 2009 | Kenwood DDX-512 Car DVD Player
I want to have the dvd player work while driving the car.
Kenwood simply requires grounding the parking brake wire.
Take the "safety" wire and ground it to your Head Unit Ground.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 05, 2009 | Kenwood DDX-512 Car DVD Player
Fitting kenwood ddx 5032 do i need to earth the park wire or run
Dec 25, 2008 | Kenwood DDX-6019 Car DVD Player
How do you unlock region codes in a kenwood KVT-7039
There are no known hacks for your model, however you ca try the following:
Try here:
Unlock Kenwood DVD players
or
"These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!"
From
Kenwood CD Unlock Code
Aug 30, 2008 | Kenwood Televison & Video
How to watch a video while not in park
1, Insert DVD. Activate Brake.
2. Next, on the main remote press stop twice, then 1,2,6,4.
3.You will see a hidden menu that says:
Region Code
Brake Override
Macrovision
Loader Version
Model Version
4. Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
5. This is what you want:
Region Code: 1
Brake Override ON
Macrovision OFF
6.When your done, click SYS SETUP on the main remote TWICE to save the settings and Bingo, You're done.
Mar 27, 2008 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
