Question about Sylvania (SRDD495) DVD Player/VCR
When I put a vcr tape into the machine, I get an Err on the time space. The tape gets jammed and I have to throw the tape away. Why is this doing this and how do I fix it. The machine that I have is the SRD3900
  • Sylvania Master
  • 11,800 Answers
The tape gets jammed and wrinkled because the capstan is moving faster than the rollers - the speed control circuit is faulty, the processor detects that and signals it in the screen . There's nothing you can do, the fault is in the IC that governs the speed and it must be replaced, and this can be done only by the repair shop of a dealer - they are the only ones that have the circuit for replacement.
Either take your VCR to one of them or get a new one (it might be cheaper).
Posted on Sep 27, 2010
When I put a VCR tape or a DVD in the machine, it will only play for a short while before the machine makes a loud grinding sound and turns off. How can I fix this?
throw it away.. ;D. probably a driver error. dont be upset, a simple clean of the machine should sort this problem. inside.. clean the inside.
Dec 30, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Vcr tape is stuck and won't eject, so TV shuts off
I did remove the faulty VCR tape manually but now I cannot download a perfectly good VCR tape in the slot ... there seems to be an obstruction like the old tape was still loaded. There is a spinner revolving when I first turn the TV on.. Can you help or do I need to take it in for a repair??
Mar 04, 2009 | Sylvania Televison & Video
MAGNVOX MWR20V6 VCR WON,T ACCEPT TAPE EJECTS WONT LOAD UP
Hello alhertel,
The old idler wheel has been replaced with gears (cheaper and last longer then the old rubber wheel). What you need to do is to gain access to the loader motor and turn it until the carriage begins to move, once the carriage gets to the top and moves outward you should be able to eject the tape with no problem.
Believe it or not VCRs are throw away technology, since it costs as much to repair one as it does to buy a new one. However, there are a lot of people who still hold on to their VCRs.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 12, 2008 | Philips VRA611AT VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
The video machine bleeps continually and shows a message E-3
I think the E3 error code indicates an error with the tape drive mechanism. If it ate a tape, this would indeed be the problem. Time Lapse VCR's are not very popular anymore, everything has gone to digital. It would most likely cost you more to fix that VCR than to switch out to a digital recorder.
Other advantages are -
No tape to change
Very good recorded image quality compared to VCR
Most digital units have capability for remote viewing over the internet
You can set the unit to "alert" you if there is movement in the garden
Sep 25, 2008 | Home Security
VCR running badly
The 180 tape is thinner than regular 120's, and they tend to stretch. Your VCR "knows" the speen and that there is information on the tape by looking at and counting the pulses on the "control track" which is like the sprocket holes on a film. The control track is a series of pulses (regularly spaced pips or electronic clicks) on the edge of the video tape. (They are magnetic and can't be seen with the naked eye.) There is a counting mechanism which - based on HOW MANY pips there are - helps the machine to determine whether it an SP, EP or LP recording, and whether there's a recording at all.
If the tape stretches, the number of pulses becomes very irregular and the machine goes haywire. (There are normally about 60 pulses in one second of tape - 59.94 to be exact!)
If the count - because of stretching - is too far away from the norm the machine the machine will "hunt" (and never find out the real speed) - trying to figure out what speed the tape ACTUALLY is running at. If there's no control track at all the machine will just stop.
Your problem is any or all of the above. Throw the tape away.
Sorry!
Aug 14, 2008 | Televison & Video
VCR Tape playing problem
The mean time between failure for the rubber parts in a VCR is about the same as the rubber parts on your car - about 5 to 7 years. You are due for a belt job.
Dec 29, 2007 | Televison & Video
VCR tape playing error
It needs its belts replaced
Jam
This Sylvania was made by symphonic Funai, and you may want to try holding in the eject button while powering it on. The cause of the problem could be anything from a defective tape to a bad gear inside the mechnism throwing it out of time or even a bad/dirty mode select switch. Unless the set is in warranty which I very much doubt, it may not be worthwhile getting repaired. The tape cannot be "forced" out of these machines without getting them out of time and the symptom would be the same as you now have. If it's not that old, maybe you could get Wal-Mart to take it back.
May 29, 2007 | Sylvania 6313CA 13 in. TV/VCR Combo
Sylvania (SRDD495) DVD Player/VCR Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
