Question about Frigidaire PLEB30S9DC Electric Single Oven
PLEB30S9DCA electric convection single oven..nothing on front panel works, panel is blank, hear a beeping noise from inside the oven behind the control panel
SOURCE: OVEN will not heat
I have the same model, 3 yrs old, and the exact same thing happened. KitchenAid made the appointment with a repair company and when the tech came out the first thing he said was "you can never use the self cleaning cycle because this always happens.' He replaced the thermal fuse thermostat and said that a lot of times the digital panel will go out and that will cost around $400. The cost of the thermal part was $80 plus his $90 labor charge. I called Kitchen Aid back, and they swore they never heard this complaint...all you have to do is look on line to see it is a major complaint!
Posted on Nov 02, 2007
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
  • 28 Answers
SOURCE: the control panel lights do
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Posted on Aug 29, 2010
tbirdfan1
  • 3051 Answers
SOURCE: What is the single fuse
Hello there and welcome to fixya
Normally the single fuse that you have found is for the electronics like the clock and the various other basic funtions o the stove ect ect if this fuse has blown out it will limit the stove or the cook top to be able to do such things like setting the timer or turning on the ovens light and it may also effect the troubleshooting program that is built into the stove ok like error codes and simple things like this
Hope this is very helpful for you '
Best regards Mike
Posted on Dec 14, 2011
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Oven electric
i have a frigidaire elite convection oven,older, the elements work but the convection oven will not turn on - what should i check?
Jan 13, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire PLEB30S9DC Electric Single Oven Logo
225 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
