Question about Amana Refrigerators
The ice maker on my Amana side-by-side isn't working right. Too much water. I have replaced the valve twice and it works ok for a little while. What else could be wrong?
  • Amana Master
  • 3,740 Answers
Take a look at this web link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
About 1/3 of the way down the page there is this statement with picture:
FILL ADJUSTMENT SCREW
1 full turn will affect fill by 40cc. 1/2 turn varies the fill by 20cc.Some Ice Makers May have knobTurning the knob or screw clockwise decreases fill; counter-clockwise increases the fill amount.Turing Adjustment Screw More than 1 full turn could damage module.
If you have 2 times replaced the water valve and you still tend to think the water valve is the problem again it may be time to use an IN-LINE water filter as you just may be getting particulate introduced into the ice maker water valve from the house connection. Particulate in the ice maker water valve seat causes them to bypass water when they are not supposed to.
I tend to think your in the right track and thinking the problem just may not be the water valve.
Use the link to troubleshoot. Just remember though that each time you cycle the ice maker using the jumper as instructed it will fill with water.
What I would to is pull the plastic hose in the back and cycle the icemaker BEFORE you make any adjustments catching the fill water in a measuring cup behind the unit. Note volume...
Make adjustment... Note volume difference. You should not have to make much more than a 20cc adjustment.
Thanks for choosing FixYa.
Kelly
Posted on Sep 27, 2010
Ice maker is not making ice it looks like no water is coming out to fill the trays checked water valve all is ok what next
test the solenoid valve with 110v jumper cord it will click if its good. some refrigerators have electric eye that shuts off the ice maker when its full of ice if that not working it will not make ice.
Dec 16, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Water vale will not open
Check to be sure water fill tube is not froze.
Aug 17, 2012 | Amana Side-By-Side Refrigerator 26 cu. ft....
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
May 25, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Amana refigator
If the dual water valve(you'll see it in the back of the fridge where the water line goes in)is leaking this water freezes up inside the filling tube for the ice maker and when it calls for water it can't go through.Or could be this valve doesn't work, in both cases it needs to be replaced.
Aug 09, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Ice maker stopped working. In door water
Hi TBurl,
Yeah... classic sign of a failed water valve. You need a new one. The part number is D7742204 (<---plug that into a search engine or call a local appliance parts outfit to get one).
Easy to replace... Just pull the fridge out, UNPLUG IT FROM THE WALL, turn the water valve off at the wall, remove the water line from the fridge valve, then remove the 2 screws mounting the valve bracket to the base of the fridge. All you have to do now is remove the electrical connectors and the tubing from the old valve and place them on the new one (making sure to get the wires right, OK?). Now just mount the new valve, reconnect the water, turn the water on and plug it in!
EASY! All in all about a 20 min. job. There ya go! Your fixed. Don't forget to rate this solution, OK? My self-esteem is depending on you. :P
SG
Jun 04, 2009 | Amana ASD2326HE Side by Side Refrigerator
Ice maker not working on Amana Side by Side refrigerator
On most Amana cabinets the water supply for the water and ice are from two solenoid valves. The water coming in goes to a double water solenoid valve splitting the incoming water so the fact there is water coming through as chilled water is not verifying that there is water supply for the ice maker. If technically minded you could locate this valve (normally at the back rhs ; compressor section) and try switching the supplies to check the solenoid valve. If you have water coming through then it may well be the icemaker module not asking for the water supply. As the simplest first step I would try defrosting the whole machine overnight and see if there is an improvement. I do know that checking the module is time expensive and would really need to be done by an engineer or alternatively replace this item. Hope this is of some help.
May 07, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
201 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
