Question about Olevia Televison & Video
I have a 37 inch HDTV LCD and the channel up and down buttons have stopped working. If you try to use these to change the channel the TV will mute. I thought it was the remote but I bought a universal remote and it still won't work. Any suggestions?
    President:
  • Olevia Master
  • 1,114 Answers
Make sure the buttons are not jammed, meaning they push in and out freely.
There also may be a "Channel Lock" feature on the set in the main menu if you can get to it. If you have the manual, check troubleshooting section. If you still have an issue,
post a comment and I will help you further.
Posted on Sep 27, 2010
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Why is there a beautiful picture but no sound and cannot change input?
Re the sound, make sure that the mute switch is not on.
Re the input, did you try changing input at BOTH the tv and remote controls. Could be the remote source button is not working.
Sep 07, 2015 | Haier HL37B 37-Inch 720p LCD HDTV
I have a olevia 37 inch tv that when i turn it on and try to change the channel it goes mute. i tried turning the channel on the tv and same issue, goes mute. sometimes when i turn the tv off and back on...
sounds like av main board in back of tv try factory reset or make sure tv is off 10 mins then open back up try giving it hoover sounds daft but a lot of problems happen dust nothink to lose hope it helps mark google how tofactory reset and then make model of you tv should find help try same youtube videos
Mar 04, 2018 | Televison & Video
If I try to use channel up or down it will only mute the sound and not change the channel
A question for you-----only with the manual buttons or with the remote as well?
Jun 11, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
There is NO SOUND from the LC3760N 37 inches TV after I turn it on. I tried these buttons: increase volume button, decrease volume button, and the mute button. The TV was working last nigth; I don't know...
The problem was caused by a loose conexion. One of the cables that goes from the DirecTV box to the TV was loose. The problem was FIXED by pushing the cables to make sure there was a good conexion.
Jun 10, 2009 | HP LC3760N 37 in. LCD HDTV
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Televison & Video Logo
75 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
