Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Kenmore upright freezer
Freezer temperature alarm is sounding and the condenser coils are iced up. The drain plug in the bottom is also frozen and filled with ice.
This freezer is a frost free.
  • 828 Answers
You have a defrost system problem. Could be the defrost timer or defrost heater or defrost thermostat. Bottom filled with ice could be from a plugged drain system. Where you termed "condenser coil" is in reality the "evaporator coil".
Posted on May 24, 2008
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
159 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
