Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Thin blue lines across the screen.6or 8 of them 3 or 4 inches apart. everything else works great still perfect picture
  • Sony Master
  • 5,138 Answers
You need to turn down the Blue Screen Drive control a notch, Blue tube has built up higher then R/G over Driving.
Posted on Sep 27, 2010
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My toshiba 55pd8800ta now has horizontal lines of picture across the whole screen. The picture and menu are out of sinc. Help!
These lines are called vertical retrace lines. Thin white lines are seen across all over the screen, at about an inch apart. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. One among the posts has details about this fault.
Apr 05, 2013 | Televison & Video
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
HD61W66YX60
this is a convergence issue. it is caused by one of three things
1. a bad convergence board
2. a bad fuse feeding the convergence circut
3. a bad relay feeding the convergence circut
whatever the one it is they all have the same result, an inoperative convergence curcut. needs service .
if it is still under warranty, great. If not the parts can cost up to $300 and labor can be the same
Nov 15, 2007 | RCA HD56W58 56" TV
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
