Question about Plumbing
My kitchen sink will not let me turn the hot water off, it just keeps running. The cold water shuts off fine just not the hot side.. I turned the knob under the sink and the hot water turned off but now i cant use the dishwasher
  • 26 Answers
Hi hi--
You'll need to rebuild or replace your hot water control stop--that's the valve on the faucet body. If it's a single handle control, you'll need to replace the control cartridge. If the faucet has two knobs, you'll need to locate whatever stem pieces are needed within the hot valve. Sometimes, on two knob faucets, you can get away with simply replacing the rubber pieces inside the control stem. If that is the case, your local hardware store should have manufacturer-specific rebuilding kits available. Be sure to locate the faucet's model name first! That should be written somewhere on the above-sink portion of the faucet body itself, and you should be able to see it without taking anything apart.
--Hope this helps.
Posted on Oct 07, 2010
Testimonial: "Thank you so much. I appreciate your help "
Why does the hot water not come on?
Sounds like your hot water shut off is turned off try opening it up and see what happens While you were working on it did you shut the main hot water line off. A person I know called me over because her hot water would not run and then she remembered that she had turned the main line off. She opened it up and away it worked.
Oct 03, 2014 | Moen Plumbing
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Machine runs but doesn't allow water to come into machine
Don't know the history of your machine, sounds like possibly the hot water supply valve under your sink is turned off. To check this go under your kitchen sink and inspect water supply valves, (right side cold water) left side hot water valve feeds the machine. Vertical water line is for sink above, there should be a second water line coming off this valve that has its own on/off knob. Make sure this knob is turned on, (counterclockwise)if not sure turn it to the right (clockwise)till stops, then to the left till it stops. This allows hot water to enter dish machine. If valve is on and line is ok, there might be a kink in the line behind the dish machine or a restriction (clog) in the water line. May need to unplug machine and unsecure it to pull it out for inspection. Good luck,best regards.
Feb 10, 2011 | Maytag Dishwasher
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
American standard kitchen faucet roars when hot water turned on
Not the aerator at all as this part would act the same if hot or cold.
Have you checked the shut-off valves under the sink? Sometimes just turning them a bit in either direction will solve that problem (will only be the case if it have been shut off at the valve recently).
Also, maybe the supply line on the hot side have been kinked?
Hope this helps
Apr 11, 2009 | American Standard Plumbing
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Hot water on cold side when first turned on moen 7600 series
did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Plumbing Logo
383 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
