Hello, im after a full set of colour coded heating diagram, y-plan s-plan
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 27, 2010
What is the firing order?
Here's an image for a Mazda firing order:
If you can't view the image, look on the link below:
firing order for 2000 Mazda Millenia Google Search
If it's the wrong diagram simply do a Google search for 'Mazda Millenia firing order'
I'm not familiar with your car ... but does it have ordinary ht ignition leads, or colour coded ignition wires?
If it has colour coded ignition wires - each wire is a different colour for each different plug.
The image below is for a 4 cylinder engine:
Mar 13, 2016 | 2000 Mazda Millenia
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
How to unlock nokia asha 306 restriction code
Hello. You can get the unique restriction code for your Nokia Asha 306 from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. Good luck.
Feb 12, 2015 | Nokia Asha 306 Mobile Phone - Unlocked |...
Radio wiring diagram
We do not have radio wiring diagrams for this model, only makes sold inthe USA. Sorry
Jun 25, 2012 | 2006 Seat Alhambra 1.9
My head set is not working so I open the
The problem is solved using the trail and error method.
As a remark: The quality of the soldering was very bad and I should have returned the headset to the retailer "Mediamarkt". Never mind I have a personal achievement.
Jan 15, 2010 | Typhoon Radio Communications
Wiring diagrams schematic (boilers)
call me alan 0776 7494009 have books on c, s,y plans
Mar 04, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Wiring diagram
the make of board is MSI model number MS 7094 ver 1.4. What I need is the colour codeing of the wires especialy the ones pow led +- which way they go as they are seperate hdd which is black and white, power sw orange and white, reset sw blue and white I have a yellow plug which says hdd audio I do know that some of these wires go into JFP1 and JFP2 but not sure which way they go as the + and -
Thanks Lipreader
Jul 10, 2008 | Intel Motherboard
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
