Question about Excelstor Technology J880 Hard Drive
I have a 80GB disk, but only 30GB is a recognized partition by Windows.i need instructions
What is the procedures on my probleM???
i have a 80GB disk, but only 30GB is a recognized partition by Windows.i need instructions
  • 99 Answers
Most likely the problem is that you have another blank partition. The Microsoft disk management tool can probably solve this. This is a tutorial on how to use it. http://support.microsoft.com/kb/309000/
Let us know if this works out for you.
Posted on Jul 26, 2008
I have 2 hard disks, 80GB Maxtor & 500GB Hitchi. Both are SATA. Recently I found my system(Win 7) on 80GB was not able to boot. I tried repairing OS but failed. So I decided to install a separate...
Full format the harddrive with disk manager tool .Remove all partition recreate 5 to 6 times untill you are able to install windows.then reinstall windows sometimes virus problem corrupt the mbr record so if you recreate the partition it will work again.
Let me know if you need further assistance.
thanks for using FixYa.
Aug 09, 2011 | Hitachi Computers & Internet
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
I cloned a hard drive which was 30gb onto my orignal hard drive which 160 gb now my original hard drive thinks its only 30gb. But the bios system says 160gb how do I repair that?
Hi. What OS are you using? The un-recognize space can be recovered by adding partition to the harddisk. If you are using Windows, you can see the empty space in disk management.
Let me know if you need help with disk partitioning and what OS you are using so I can write specific solution. Thanks.
Jul 15, 2010 | Computers & Internet
Hi i take dell laptop with 320 gb hard disk & 4 gb ram with os installed only one partition actually i want 3 partitions. It is possible give solution
you cannot split the partition while its in use.
THE FOLLOWING WILL ERASE THE ENTIRE DRIVE.
put the OS dvd into the machine
power on
hit F12 key when the dell logo appears
select the cd/dvd drive.
the machine will now boot from the OS disk
follow the instructions until it asks where to install windows.
At this point you can split the disk into as many partitions as you like providing you choose a partition of at least 30Gb for the OS to be installed on.
Jun 15, 2010 | Dell Latitude D600 Notebook
Toshiba MK6034GAX Shows only 30gb
Linux may be on another partition and Windows cannot recognize it, otherwise the MBR could be damaged and you should conect it externally and run a disk check on the drive.
Jul 18, 2009 | Toshiba (MK6034GAX) 60 GB Hard Drive
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Hard drive not recognized
Is it detected in the Disk Management wndow?
To access Disk Management: Click Start>Run and type in DISKMGMT.MSC and click enter.
If it is detected there right click on it and select Partition and after partitioning the drive you can format by right clicking on it again.
Good Luck!
Mar 09, 2008 | Computers & Internet
Harddrive problems
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Internal 80gb harddrive excelstor j880
Using as startup disk
If you used Acronis, you need to clone the 30Gb and not backup. In doing so, the booting information is likewise copied to the 80Gb, whereas back up is simply copying contents (that you specified) hence will not boot and not be active.
Pls remember that by cloning, Acronis would erase the partition (and contents) of the 80Gb. At certain settings, it would also split the 80Gb into 2 partitions; 30Gb & 50Gb. Further, verify that the 80Gb is "Set Active" and partitioned as a Primary and not Logical.
As to your other concern of installing, in some instances, some not so recent motherboards' BIOS/CMOS will not recognize the 80Gb. Other than that, you were doing it correct; new 80Gb as primary/master with jumper to the pins nearest the IDE cable, any other device (CD ROM or another HD) should be set as primary/slave (SL). Additionally, pls verify that your motherboard auto-detected your new 80Gb as your primary boot media (settings in your CMOS/BIOS).
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 03, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Excelstor Technology J880 Hard Drive Logo
141 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
John Anderson
John Anderson
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
