Question about Ricoh Aficio 1232C Color Copier
What is SC305 Error Message - Ricoh 1232C On
What is SC305 Error Message - Ricoh 1232C On startup states "adjusting colour", then get the error message.
  • 1,110 Answers
I worked on this same code just the other day for a customer. This SC305 code means the charge corona cleaner is not working properly. The charge corona is located behind the large front door, towards the bottom and just left of center. It has a small thumb screw and a white cord with an end on it like a telephone cord. You can try removing the assembly and blow it out carefully with canned air. Be careful about the very thin hairlike wire in the shell. You can also remove the end of the unit and check that the motor is not gummed up. If it is just put a little light oil on it. Just cycle the power off then on again to reset and try.
Usually once they get repositioned properly they will work fine. Sometimes I have replaced the unit with one from a parts machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 27, 2010
Error SC305 on
An error has occurred in printing.
  1. Make a note of the error message (for reference later).
  2. If the error re-appears, please contact your local authorized sales/service representative or original point of purchase.
For the time being, try restarting the device:
  1. Press the Clear button to clear any pending jobs from the Printer.
  2. Switch off the device at the Red Power Switch, wait for 5 seconds then switch on again.
May 07, 2013 | Office Equipment & Supplies
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Serice code 792
E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E792 Sorter stapler error
Mar 20, 2009 | Office Equipment & Supplies
Richo aficio error sc305
Hi All,
Charge AC Bias Error
Check connector for Magenta PCU
Replace the Magenta PCU
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232C Color Copier Logo
1,448 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
