Question about Taylor & Digital Scale Lithium Scale
Taylor model 7538 shows err 1. I bought new batteries. I stood on scale for 10 secs without battery, replaced battery. Scale goes to 0.0, stand on it, it says err. Took battery out again, stood on it for 10 secs, replaced battery. Let scale turn on tapped corner, it says I weigh 269 lbs or 48 lbs. I am in the 135 range. This scale only worked a few times when I first bought it. Very frustrating. I will never buy another one. The only reason I keep it is because I threw the original package away and it cost me $27.00. Please help, kathy
5 Suggested Answers
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
robocop
  • 90 Answers
SOURCE: need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Posted on Jan 22, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
F1xer
  • 415 Answers
SOURCE: Taylor Model 7314 Lithium Scale: Scale
Try stepping off the scale when you get an error message wait 5-10 secs then step back on, remember to stand still when the scale is giving a reading
Posted on Aug 15, 2010
We have a Taylor 7538 scale and I need battery number.
CR2032 3V Lithium Battery
I think 2 of these above battery lithium battery
Jan 09, 2015 | Taylor Health & Beauty
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
Scales are getting a Err 1 message, installed new batteries, need to reset them some how. They will not zero themselves out
My scale was fine the other day. I weighed myself earlier in the day. I tried to weigh myself later in the day and the scale started reading ERR1. I called Taylor and they had me try to "reset" the scale twice. It did not work.
The steps for resetting it are:
Turn the scale over
Remove the batteries for at least 10 seconds
With the scale on it's side (even though you aren't supposed to put the scale on it's side, carefully insert the batteries and put the back on the scale
Slowly return the scale to a flat hard surface
Step on the scale after about 10 seconds of it being back in position
If the scale still jumps with crazy numbers and reads ERR1 try to reset the scale again being very careful when the scale is on it's side
If this does not correct the problem then the scale will need to be returned to the manufacturer, to the address on the label on the bottom of the scale
I was told you could put the scale in any box and ship it to them the cheapest way possible but be sure to keep the batteries with you
If you are still under the year warranty they will send you out a new scale in 4-6 weeks
I was not happy that my scale was purchased on 11/14/09 and it died on 02/12/10. Luckily I knew where my receipt was. I pulled it out and noticed 02/12/10 was the last date to make returns to Target for that transaction. I was able to go and return my scale to the store because it was in the 90-day window that I had purchased it.
I was told that the reason the scale was doing this was either an delayed electrical interference that may have occurred during. The only other reason I was given was an OVERLOAD. Well, I seriously doubt an overload was my issue. First of all I was the only person at home that day so nobody else stood on the scale. I had used it earlier in the day and it was accurate. I am 5'6" and 139 lbs. so I seriously doubt it was OVERLOAD unless someone isn't telling me something and I need to lose some serious weight.
Anyway, I hope this helps. I wasted a lot of time trying to figure it out that day. Now I have my new receipt and if this happens again I will go get my new scale just as I did this time. I thought a 4-6 week wait for a replacement scale was insane. Kudos to Target for taking the scale back without a box or instructions on the last day I was able to make a return.
Feb 09, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Taylor & Digital Scale Lithium Scale  Logo
573 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
