Question about Panasonic KX-TG2356 Cordless Phone
No dial tone on hand set battery is new lights up
No dial tone on hand set battery is new lights up buttons all appear to work
    Sergeant:
  • 270 Answers
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Posted on Sep 27, 2010
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
Can not break through dial tone on either hand set
After going around and around and around with YOU people, I finally gave up and took the damned phone back to the store where I bought it. The first store wouldn't take it back, because I had the receipt (which was from early September, 2008 - which was past the 90 days), so I took it to their other location and told them that I lost the receipt. I got a brand new replacement. If the new one should fail to work, I'll take it back again WITHOUT the receipt, and upgrade to another brand. Thanks anyway.
Mar 27, 2009 | Vtech Lands Phones
Handset
I guess its time to get new batteries
Sep 23, 2008 | Sony SPP AQ600 Cordless Phone
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
Voicemail
Press and hold the "Mute" or "Clear" button until the handset beeps to clear the New Voice Mail allert.
Jul 04, 2008 | Panasonic KX-TG1033S Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Panasonic KX-TG2356 Cordless Phone Logo
199 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
