Hello I have a monitor philips 190WV and suddenly contrast went 100 and i cannot change it cause if i press a button the only thing i can see is CONTRAST 100... also to disappear this message the only way is to remove the cable feet .. please help me cause contrast went very high. Thanks.
    Problem Solver:
  • 7 Answers
I had the same problem. It was due to the right button being stuck.
I was sure it had to do with the contact and was dismayed to find ot you need special equipment to unscrew the back of the monitor off...
But luckily i solved it by flipping the button with my nail at the edge of the button.
The sudden press&release got it unstuck...
Hope this helps :)
Posted on Oct 18, 2011
  • GeorgeM Oct 21, 2011
    update: After opening the cover I poured some ethyl alcohol on the faulty OSD button next to the menu and fingers crossed it works fine now for more than an hour (without any of the annoying pop ups or auto increases of the contrast....) Fingers crossed this will last or else I read that you can completely remove the connection of the buttons microcircuit board provided the settings are good - I didnt try it since it works well with the cleaning. See what I did:
    Unplug all cables from the monitor so as not to get an electric shock!
    Lay it on a flat surface and remove the 3+1 screws from the back. Remove carefully the back cover. There are 7 clips up and down and 5 clips left and right every 4 cm or so, they are tricky to take them apart but if you use a flat screwdriver and put it between the front and back cover press inside a little bit and twist it you can make it.
    Take off the buttons board after unscrewing the two screws and pour generously ethyl alcohol on the button(s) contacts. Let it dry and assemble again. If it works fine say thanks to God and me and drink a beer :)
I got the same problem .. can anyone help?
Posted on Nov 14, 2010
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
got wood I would just build my own...cheaper and you can customize it to your like..
May 10, 2014 | Philips 190WV
Philips monitor osd locked
you have to carefully force open the clipped back case of the monitor and disconnect completely the cable to the front control buttons, then the monitor works fine though no adjustments can be made
Jan 12, 2014 | Philips 190WV
No light in Philips lcd 190WV
Has it got power? Is it turned on? Is the PC attached to it? First check all your cables & power outlet.
Feb 06, 2013 | Philips 190WV
I have a Phillips and suddenly a screen appears with the menu and a message saying MONITOR LOCKED KONTROL then this is ...
This is a problem on the board with the buttons located at the bottom of the monitor. Must be disassembled the monitor and this board must be disconnected. This is the quick and easy solution.
Dec 23, 2010 | Philips 190WV
I have an philips 190WV monitor. From times to times the "brightness option shows up and changes to zero without pressing any button on the monitor. Any ideas ?
i got the same opposite problem. my contrast goes up 100 and i can't change any thing.
have you figured out your problem? if yes, how?
Sep 05, 2010 | Philips 190WV
MONITOR MENU EXIT BUTTON ARE NOT WORKING
This is the exact same problem which I am facing at this moment. I opened the Case of the monitor. I saw that there are 2 small buttons with a extended rod attached which goes into the buttons on the Monitors body. I saw the Contrast button is stuck. I also saw that the monitor pads and the monitor sensor board has complete rust. I think I have to change the button pads and the Monitor Board. The same thing I am seeing in your case. I think this is a cause of Excessive moisture content in the air which is causing rust and jamming of Buttons.
I think now you can get what to do.
Thank you Sir, Have a nice day.
Sep 23, 2009 | HP w17e Monitor
On start, monitor contrast option automatically gets activated
if nothing works and you cannot access your monitor settings via the menu button on the monitor then you have no way of correcting it. as far as i am aware the only thing you can change with the monitor from within your operating system are its resolution, refresh rate. so i think you need a knew monitor.
Apr 23, 2009 | IBM E54 15" CRT Monitor
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
