Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Hi i have a ge profile side by side. the digital temp inside the refrigerator side is reading frezzer 23 refrigerator 47. The frezzer wall is iced up. when i press against the frezzer wall the coil feels like ice. Everything was defrosted The fans has not come on and the compressor did not kick in. I been putting the express chill on so my milk doesnt go bad. in the refrigerator part. Do you think the heating fan went or the theromstat went. also how would i change the part meaning how would i get to it. Do i have to go threw the actually frezzer or in backof the refrigerator. I brough this product back in 2006
  • 4,059 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Sep 27, 2010
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
G e profile refridare the frezzer and the freide are both to warm and we had to take food outof the frezzer. i hear it running. water comes out of the ice maker all the ligts work and the dors seal. what...
Hi, I once had this problem. My freezer and refrigerator were both warm, but I could still hear it running. When the repair guy came out he immediately checked the back interior of the freezer (had to remove a panel) and it was entirely frozen solid with ice. He said the defroster had stopped working, which caused the coils to all freeze. It took him about an hour to get all of the ice off. He replaced the defroster. Total cost was around $250.00.We have a GE side by side Profile, about 8 years old. Works fine now.
Jul 19, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
May 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dripping inside of freezer, forms ice-cicles, water doesn't dispense and temp. rises on both freezer and refrigerator.
Check rear inside wall of freezer for frost build up, this prob is an indication that you have a defrost problem, like a bad defrost heater or defrost control.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
115 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
