Question about Sony Playstation 3 (PS3) Console
I turn my ps3 on the green light comes on then about a second later the blue light turns on as well but then flashes yellow and then beeps three times and flashes red what could the problem be
    Problem Solver:
  • 15 Answers
I assume you have a "fat" PS3
That is the YLOD! The system has most likeley overheated, and the 2 main chips probably lost their connection to the mainboard. A reflow/reball will be needed, if this is the case.
Take it apart, and find the main chips (they will be on the bottom of the board, and be large and silverish in appearance.
Do the same thing that this guy does to the Xbox 360, only with your board/chips:
http://www.dailymotion.com/video/x7xcuj_xbox-360-bga-reflow_tech
Some good info here too: http://www.overclock.net/playstation/490463-ylod-fix-ideas-preventing.html
I'd recommend using flux.
You may substitute a heat gun for the reflow station, though the controlled process is always better. Be careful - too much heat may destroy the chips.
If that doesn't work, the second most likely cause would be a power supply, third, a break in a trace in the Mainboard.
Good Luck
Posted on Sep 27, 2010
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 80g light turns green flashes yellow, then
Unfortunatly your ps3 is dead, I am sorry for your loss.
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
The green light comes on for a couple of seconds then turns red and the game won't come out
This sounds like the "Yellow Light of Death". Does the console power on, flash a yellow light then go back to red, while beeping three times?
This YLOD is caused by excessive heat inside the console. Typically dust builds up and causes the machine to overheat. This damages the internal components. The good news is that a skilled professional can fix your problem.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on then 5 seconds later the green light
well i can tell u this. If your having any problems then 1.turn on your ps3
2.hold down the ps3 button until it beeps and turns red 3.then hold it again it should beep twice 4.then a screen will pop up with options 5.choose the one that your having problems with 6.it shouldnt turn off but if it does call the geek squad or get one of those ps3 fixing books.
i have a problem of my own 2 of my games froze while loding and one just froze while loding the first level of the game can u help me?
Oct 03, 2009 | Sony Video Game Consoles & Games
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
I was just playing a game on my ps3 and it shut down, so i tried to start it back up. it turned on then seconds later it went yellow then to a flashing red light with the three beeping. the fan kicked in...
Same **** happened with my PS3. So I returned it, and got the newer version of it. I went home and plugged it in: The fan came on along with a green light. BUT THEN..... 5 seconds into it, the damn thing shuts down and flashes red along with the three beeps. Not to mention the yellowish orange light. Even the brand new version did the same ****. I am in your same position and I would love to hear a way to fix this. Pretty weak.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
