Question about MSI Wireless-G RG54G3 Router
Can Not Connect
I have Bellsouth DSL internet service with a Westell Wirespeed modem. Everything seems to be working correctly but I cannot connect to the internet. I have followed the setup instructions and set it up per instructions and it still won't connect.
I have msi RG54G3 when i type 192.168.1.254 the page cannot be displayed come up
Posted on May 28, 2008
Modem installation
It is not a lost cause BUT you will have major issues connecting to most websites because the browsers are so advanced now that if you connect, it wont display correctly and there is an issue with some secure servers rejecting you because the operating system can be read and the server wont allow the connection.
http://www.dslreports.com/faq/bellsouth/3.14_Westell_2100_2200_6100_Info#7342
Jul 26, 2017 | Westell Wirespeed Westell Dsl Router Wind...
Need to connect to another computer in home
bellsouth will walk you through the instructions step-by-step if you call them up.
Jan 19, 2010 | Westell Wirespeed VersaLink...
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
How to use bellsouth router on windstream internet
yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now sitehr@gmail.com
Aug 16, 2009 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
WESTELL WIRESPEED DSL MODEM B99-210014-03
Probably not - contact your DSL internet service and ask what modem they suggest.
Sep 26, 2008 | Westell Wirespeed LiteLine 6100...
MSI Wireless-G RG54G3 Router Logo
147 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
