Question about Maytag MER5770 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on the rear element, the front dual element also turns on, but only the inner portion. The knob for front element is OFF. I'm suspecting that its the dual limiter must be shot. Your comments and suggestions are greatly appreciated. RA
  • 1 more comment
  • Anonymous Jul 05, 2008
    im having the same problem...did changing switches fix your problem?
  • kquach Oct 26, 2008
    I have a kenmore electric range smooth top. One of the surface elements doesn't work. How do I fix it?
  • Anonymous Dec 03, 2008
    I am having the same problem on my Maytag. The right radiant element went out,it has juice because i accidentlly touch it and got a shock. I have the Model # 79096012401. I need to replace the element PLEASE HELP. I would like to have husband change it himself,but how do you do it?
I am having the same issue. I had a repair man come and replace both switches but it didn't help. If I turn the rear burner switch on the front burner turns on as well. Any suggestions?
Posted on Jul 31, 2012
    President:
  • Maytag Master
  • 2,651 Answers
Yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
Posted on May 24, 2008
2 Suggested Answers
  • 521 Answers
SOURCE: replacing a radiant element on
you are very right the dual limiter is exactly short.
Posted on Aug 19, 2008
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
I have heard that when the bake element flares out that there may be damage to the oven electronics as well. Is that a common problem or will I be able to just replace the element & have an...
the elements are designed to burn out or go to ground there are 6 safe units to protect the m10 so the electronics should/must be ok replace the elements and youl find your right back on track
happy dinning
Jun 24, 2010 | Maytag MER5770 Electric Kitchen Range
I have a Maytag MER5770AAW replacin element
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Feb 02, 2010 | Maytag MER5770 Electric Kitchen Range
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Replacing smooth top
Have you purchased a new top yet? If you haven't, you can find it at repairclinic.com for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Feb 11, 2008 | Maytag MER5770 Electric Kitchen Range
Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Aug 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5770 Electric Kitchen Range Logo
487 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
