Question about Sony KDF42E2000 42" HDTV
My Sony KDF42e2000 goes on and off every 30 seconds. The picture looks good when it's on. Does this mean I need a new lamp? There are no "code" flashing. The power light is solid green when the screen is on and then continues to blink green until 30 seconds later when the tv comes back on. Please help.
  • 10,594 Answers
Yes, its symptom of weak lamp that has been reached to end of its life. If lamp has not been replaced in last 2-3 years, replace it to solve tv issue.
Thanks.
Posted on Sep 27, 2010
Testimonial: "Great advice!! TV is working great with new lamp. Easy to replace on my own and save over $100. Thank you very much!"
When I turn the TV on, it has good picture, then 30 seconds the screen goes blank, then 30 seconds later it comes back on. Repeating this continuously. What do I need to do.
Its time to replace Lamp in tv as current lamp is near to an end of its life and causing this problem.
Lamp replacement is easy and user level job, procedure would be mentioned in user manual.
Please buy Sony original lamp for better picture quality.
Let me know if you have additional question.
Thanks.
Apr 12, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture is good but it stays on for about 30 seconds then goes off for about 30 seconds or so ,the lamp is coming on then going off ,what is the problem, I have replaced the lamp one time before.
Pull the lamp out and have a look at it. If you don't know what you are looking for in regards to damage, have a look at my Tips & Tricks. I have a tutorial on projection lamps. It will show you where to look when inspecting a lamp. I hope this was helpful, best wishes.
Apr 02, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have 42in kdf42e2000 and it keep cycling on and off
If the TV cycles 3 times then shuts down or the picture goes on and off then I suspect you will need to replace the projection lamp. The part number for the lamp is F-9308-750-0. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Sony KDF42E2000 42" HDTV
I have 42in Kdf42e2000 and it keeps cycling on and off. it stays on for 45 sec and the shuts off power light blinks for 42 times then it goes back on and the cycle starts again. Does anyone know what could...
Its symptom of weak lamp in TV, please replace lamp.
Lamp replacement procedure is easy and mentioned in instruction manual, if you need copy of manual, click Sony Support.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
You can buy replacement lamp from Sony Accessories Store under following part number..
F93087500 Lamp Block Assy XL-2400
Thanks.
Jul 09, 2009 | Sony KDF42E2000 42" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony Flat Screen XBR
your lamp may be going bad.
replace the lamp by sending it to sony (if under warranty) or order a new lamp from sonystyle.com .
the location of the lamp should be in the manual.
Aug 23, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Jan 17, 2008 | Televison & Video
Intermittant lamp cycling
could be lamp or lamp driver the only way to tell is to replac on at a time.
Aug 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF42E2000 42" HDTV Logo
272 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
