Question about Peg Perego John Deere Turf Tractor
In high gear only one wheel turns, low gewr and reverse have no power. Could it be the switch ?
  • Anonymous Sep 27, 2010
    could be one prong on one of the motors are broken. look at the on that does not tuen in low.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Nope, its a bad motor, you can get a new one here www.powerwheelsoutlet.com
Posted on Jun 06, 2012
  • 156 Answers
SOURCE: won't run in low gear and won't go in reverse
It has a wire that has come off the motor or the switches in the shfter need to be replaced
I get all my replacement parts at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
because they also help me with my repair questions.
Hope this helps
Posted on Jul 10, 2009
  • 156 Answers
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
Posted on Jun 08, 2010
SOURCE: both wheels will not move in high gear, only one
how do i take a part the gear box from the motor
Posted on Jun 10, 2010
  • 24 Answers
SOURCE: Neither wheel spins in low
Yep. Its either a burnt out motor (the one that isnt spnning) or the connectors under the gearstick need cleaning, or check the wiring on one motor. It works by putting the motors in parallel for high, and series for low - and if the series has a break anywhere - nothing runs. If you need a motor - visit http://www.wackywheelers.com/shop
Posted on Sep 22, 2011
  • 24 Answers
SOURCE: no wheels turn on low
Posted on Sep 23, 2011
Do both wheels turn in second gear on john deere gator?
yes both wheels should turn in all 3 gears, high low reverse
Jun 08, 2014 | Peg Perego John Deere Gator HPX Ride on...
Both wheels will not move in high gear, only one wheel will spin, they both work in reverse and low gear
It sounds like you need to replace the peg perego switch assembly for the gator, I upgraded my shifter and it works great now, but I also found the additional switches at http://www.mypegperegoparts.com/
Jun 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Tractor won't go in low gear or reverse
u might need to get on ebay and try to find a new switch
Apr 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Won't run in low gear and won't go in reverse
Hope this helps
Jul 09, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Little Tikes Hummer
Its the battery, you can purchase new one on amazon. here: Amazon com little tikes hummer battery. I hope this was helpful. cheers
Mar 06, 2009 | National Little Tikes Hummer Yellow
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Turf Tractor Logo
77 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
