Question about PANDIGITAL PANSCN01
The scanner seams to light up ,it pulls the picture through like its suppose to do but it does not copy on my sd card??
SD card was suddenly formatted. What can I do to rescue card images?
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Oct 20, 2014 | Samsung Cell Phones
Pictures not showing up in gallery. when I click on a black square where a picture is "suppose" to be, screen shows loading picture
you have some damaged files.you will need to copy your stuff from the sd card and scan it u will see the damaged files.den format your card and put back your files but dont put the ones which showed were damaged
Oct 21, 2013 | Boost Mobile Kyocera Hydro Smartphone
Have "olympus sp 800uz" and
1. Put the SD card into the computers cardreader.
2. Connect the camera through USB with the computer .
3. Copy the pictures.
If you have trouble with the SD card:
1. Copy all the pictures to the computer.
2. Format the sd card in the camera.
3. Copy the pictures back onto the sd card.
Aug 31, 2011 | Olympus SP800UZ Digital Camera
How to tranfer picture from camera to flash drive
Connect the camera to the computer with the supplied USB cable. the computer will see the camera as an external storage device. You can then copy the photo from the camera to the computer's hard disk and or your flash memory stick.
If you camera has the photos stored on a SD memory card you can remove the SD card and insert it into an USB memory card reader. Then connect the card reader into the USB port of your computer to download the photos from the SD card to the computer's hard disk and or your flash memory stick.
Aug 21, 2011 | Computers & Internet
I had several pictures already scanned to my computer.I wanted to add some more,without the ones already in there being sent again so I thought if I formatted the sdcard it would delete the first...
Uh-oh, that's indicating that there are no images to scan on the SD Card. If you reformatted the SD Card, I'm afraid those pictures are lost. :(
Your scanner might have internal memory, check your user manual to see if this is the case. If it does, some of your pictures might be stored on the scanner's hard drive.
Jan 21, 2011 | VuPoint PDSST410VP
How do you delete pictures and copies from the VuPoint Magic Wand?
Your VuPoint Magic Wand scanner should have come with a USB cable. Use the cable to connect the scanner to your PC, and the memory card in the scanner appears as a removable drive in Windows Explorer. Deleting files from the card is just like deleting files in any Windows folder -- just highlight them and press the Delete key.
Nov 12, 2010 | VuPoint PDSST410VP
Can't put pictures on the camera
you can do something
1.take picture in camera .
2.copy the of the picture .
3.go to the picture you want to put in camera .
4.past the name on the picture.
5.change the dimensions of the picture to 3264x2448 or 2448x3264
6.then put the picture in camera (sd card)
its work with me
Jul 26, 2009 | Fuji FinePix J10 Digital Camera
Copying pictures from laptop to SD card
r u able to see the SD card in my computer if yes chk the free space in it if its empty then right click on sd card icon and formatt it it will erase all the data from ur sd card and then it should copy
May 17, 2009 | HP Pavilion dv6000z Notebook
PANDIGITAL PANSCN01 Logo
20 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
