Question about iLO 2600 Television
Our 46-inch LED flatscreen seems to have glitchy video reception last night. After about 10 minutes it then lost video completely. All the power sources and jacks are fine and the green power light is "on"....there's just no picture. At first the television seemed to cycle through some kind of pattern (full screen colors: magenta, green, blue, etc). And then nothing. It won't even turn off using the remote or on the side of the TV.
  • dididance Sep 27, 2010
    It is not happening on any other televisions.
  • dididance Sep 28, 2010
    I have switched the cable boxes and it is not a problem with my provider.
  • 666 Answers
Well if you still have audio it may be as simple as a video fuse if u dont have audio than I would say your power supply needs to be replaced neither is very costly but if you end up having to replace the board I would say just purchase a new tv
Robb
Posted on Sep 29, 2010
  • iLO Master
  • 5,138 Answers
Problem will lead back to the Main Board.
Encompass Parts Distribution might have board in stock
Go to their website or Call 1-800-638-3328
Posted on Sep 28, 2010
  • 10,865 Answers
Call your service provider and report this problem. This may be their problem and not yours. They may be able to fix it remotely. J.
Posted on Sep 27, 2010
Is there a reset button on television? storm last night but the set was off?
There is no such external button; to reset. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 14, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I'm on my second nuvi 255w. As before this ine has
I am in the same boat as you.. I am on my 2nd 255w unit as well. The first one lasted 2 weeks. This one about 45 days. The thing I noticed, which may be coincidence, is I updated the software and map a couple days prior on each unit before problem occured. Last night the 2nd one lost satelite for about 5 hrs, an area I deliver pizza's in everday with no other problems. No mountains, no tall buidlings, yet I decided then to power off unit completely, stand outside and turn unit on. I waited about 10 minutes then put 255w back in vehicle in which at that time still was not working. But 30 minutes later when I got back into vehicle it was working again for the rest of the night. Not sure if standing outside corrected or not, but it is working again. I would be curious to know if the software update and map update plays a part in the problem.
Sep 25, 2009 | Garmin nuvi 255W GPS Receiver
Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
Sep 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
24 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
