Question about Samsung HL-S5087W DLP TV
I recently replaced the bulb in my rear projection tv, now im haveing problems with what i beleive to be the bulb fans, something is whistling and the screen isnt coming on ?
  • Samsung Master
  • 5,138 Answers
That whisling sound you hear is the Color Wheel it needs to be replaced. Encompass Parts should have 1-800-638-3328
Posted on Sep 27, 2010
JVC HD 56g886
It could be dust and or lint in the tv. The bulb has a fan to cool it and if it is plugged with lint can cause the bulb to overheat and fail. Lint or dust that gets on the bulb can also cause premature failure. Remove bulb and lean fan and intake screen thoroughly and check to make sure fan is operating. Then install new bulb. Hope this helps.
Dec 31, 2013 | JVC HD-56G886 56" Rear Projection HDTV
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
Jan 12, 2009 | Toshiba 57H81 57" Rear Projection...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Dec 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Samsung HL-S5087W DLP TV Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
