Question about TruTech T300B Boombox
I have a Trutech boombox Model # T250 B. My antenna got broke. I was unscrewing the broken antenna but the base fell inside the boombox. How do I get it out? I'm afraid to play a CD for fear it will be ruined. I also have that same fear if I play an audio tape. You can hear the base of the antenna rolling around on the inside of the unit.
4 Suggested Answers
  • 63 Answers
SOURCE: Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
Posted on Aug 19, 2009
  • 417 Answers
SOURCE: I need a replacement antenna for a Delphi boombox.
Try radio shack. #270-1401, #270-1405
http://www.radioshack.com/family/index.jsp?categoryId=2032206&cp=2032057.2032187.2032189
Posted on Apr 06, 2010
toolkits
  • 1099 Answers
SOURCE: fm rod antenna
Hi, The antenna can be replace ,in which you have to open the back cover of the appliance and you get the antenna from an electronic shop
Posted on May 19, 2010
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
My antenna to a 2004 saturn vue broke off at car wash how do I get the base off to replace antenna?
they usually unscrew from the inside but im not 100% sure on your model.
Jul 02, 2013 | Cars & Trucks
Fm rod antenna
May 19, 2010 | TruTech T350B Boombox
Pontiac vibe broken antena
Unscrew the top cap and remove it. Then Lower the antenna to see if there is a swivel you have to hold vertical to get it through the hole . the cable needs to be disconnected from the radio Get a new ant. and you will see the swivel uou need to hold vertical. good luck.
Jun 02, 2009 | 2005 Pontiac Vibe
Replaceing a broken antenna mast on a 2005 Ford focus
I am pretty sure if you remove the inside dome light cover and take out the light there is a bolt and nut under there for the base that you can unscrew. By the way where did you buy the parts from, Ford is telling me $70 for the antenna whip?
Jan 21, 2009 | 2005 Ford Focus
2003 Ford Focus radio antenna broken off.
Should be a dome light in the interior that lines up with antennae on roof if it's same as I remember. Remove interior light and there should be screws in there holding base of antennae to roof. If it's just a broke off mast, try to unscrew stud from base & replace.
Jan 10, 2009 | 2003 Ford Focus
Antennae broke
Just go to any radio shack they have lots of antennas
Oct 27, 2008 | RCA RCD110 Radio/Cassette/CD Boombox
Radio plays sometimes, won't others. is getting power, fm stereo indicator lights up when tuned in to a station, but no sound from the speakers, not even static
maybe the amplifier inside is failing if you turn it all the way up for a second and it comes on then it is the amp but if you wiggle the vol and it comes on the its the vol switch
how did the speakers sound ?
Oct 11, 2008 | Emerson PD6810 CD Boombox
The antenna is broken at the base eye, and repeated attempts to re-attach the eye have failed.  How can I purchase a replacement antenna?
It's possible to get the same antenna on ebay...
You can check here:
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inches-Boom-Box_W0QQitemZ120194279381QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
or here
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inch-Sony-RCA-Coby_W0QQitemZ120194280040QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
Dec 02, 2007 | Jwin (JX-CD512D) Sports Portable CD Player...
TruTech T300B Boombox Logo
131 people viewed this question
Top TruTech Audio Players & Recorders Experts
David Payne
David Payne
Tom Chichester
Are you a TruTech Audio Player and Recorder Expert? Answer questions, earn points and help others
