Question about Kenmore Washing Machines
Dishwasher has become very noisy and does not clean the dishes like before it is about 4 years old
  • 905 Answers
More than likely, your impeller has something lodged into it. Check the strainer (back wall, on floor) for utensils and such that may have worked their way there.
Plug your model number in @ searspartsdirect.com and you will be presented with a variety of diagrams. You want the diagram that shows how the pump is attached. You will have to remove the dishwasher from the cabinet (unless its portable) to access the pump assembly. Then check the pump. You may have also bent / broke an impeller blade. Given the age of your dishwasher, there may also be a service manual available for it as well.
Posted on Sep 27, 2010
Leaves a white soapy film on pots, pans and dishes
Are you overloading your dishwasher? Are you loading the dishes in such a way to cover the water shooting up from the blades? Have you run your dishwasher a few times with no dishes in it, adding straight white vinegar to clean it out? How old is your dishwasher?
Apr 02, 2013 | Whirlpool Dishwashers
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
8 year old dishwasher has increasing gotten more noisy during wash cycle.
change te winding of the mortar or change the mortar or clean the whole dish
Apr 23, 2011 | Dishwashers
Noisy dishwasher
I have the same problem. I have been checking around on the internet, and it seems that the problems points to the bearing in the motor.
May 12, 2010 | GE 24 in. GLD5860LSS Stainless Still...
2-year old unit. Cleaning quality has become
Clean your machine using White Vinegar
You can remove your spray arms and soak them in Vinegar to unblock them blowing out rubbish and unblock the small holes
Feb 23, 2010 | KitchenAid 24 in. KUDS02SR Built-in...
Has become very noisy during sensing cycle.
Either the motor is failing to pump water or there is too much soap in the system. Add 1/4 cup veg oil and run again.
Sep 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
