Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
    Scholar:
  • 71 Answers
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Posted on Sep 27, 2010
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
Fuel mixture
Use the provided link for fuel/gas mixture.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 21, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
I have a Homelite-terry TEXTRON chain saw does it take a gas oil mixture?
I have a Homelite Terry Textron X76 T83-03010 Unit 50150.
how do you change the fuel line?
Sep 02, 2012 | Garden
Fuel and two stroke mix pls oil type for chain pls
For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  • Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Mar 20, 2011 | Oregon Cutting Systems Chain Saw Cutting...
My chain saw is kicking out alot of smoke, making it quite sluggish, of recent it takes a little longer to start. Having left it a couple of mins. to warm up, it is now conking out when i increase the...
One thing to check is your oil/gasoline mixture. If the gasoline that you used is alcohol enhanced then if you let it sit for a period of time the alcohol evaporates and the mixture changes to more oil than gasoline mixture which makes the exhaust smoke a lot and possibly coats the plug more. Also, regular gasoline that sits in the tank for a long period of time does the same thing.
If your mixture is not at the recommended level,16/1, 40/1 or 60/1 whatever, then the oil will foul the exhaust ports on the saw and back pressure will cause the saw hard to start.
Recommended: take the muffler off of the machine and clean the exhaust ports as much as possible, scraping the built up carbon off. clean the gas tank out removing all of the mixture. Refill the tank with fresh correct mixture. Remove the spark plug and clean or replace being sure that the plug is gapped correctly.
Nov 27, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What type gas mixture is used in McCulloch chain saws?
40:1 is a safe bet for just about all chain saws.
Jul 02, 2010 | McCulloch Garden
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
191 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
