C an i hook up a wireless connection on my laptop off my modem
    Scholar:
  • 64 Answers
HI eugeneforgus
as long as you have a wireless card "builtin" or otherwise on your laptop and your modem is a wireless router also.
The answer is yes.
Posted on Sep 28, 2010
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
How can i connect my compaq presario 1245 laptop to my cable modem via my wireless or wired router?
You can hook it up with a Ethernet cable from modem to laptop or if you have a wireless network setup at home you should be able to see your wireless network your laptop click on it and whala!! connected.
Feb 25, 2011 | Compaq Presario 1245 PC Notebook
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trying to incert a wireless modem
There are several types of wireless modems available.
A PCMCIA wireless card that inserts into the laptop's PCMCIA slot.
A stand alone wireless modem that connects into the LAN port (10BaseT connector) with a network cable or a USB cable to the computer's USB port.
and
A USB wireless device (similar in size as a USB memory stick)that connects into the computer's USB port.
Feb 21, 2009 | Dell Latitude D600 Notebook
Laptop will not connect to the internet anymore.
are you using wifi connection, I mean wireless connection or you're hooking up to a LAN network or through a modem connection?  If all this connection wouldn't worked out anymore, try reinstalling your Operating System!
Dec 13, 2008 | Acer Aspire 5100 Notebook
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
MY WIRELESS LINSKYS HOOKED UP NOT FINDING MODEM/CANNOT CONNECT
You don't use a modem to connect with a wireless router. Connect an ethernet cable between the laptop and the router to ensure that both are working. If this gives you an internet connection then the commonest problem is an incorrect wireless key. Reset the key on the router then cut and paste it into the wireless network setup in the Control Panel. Wireless drivers are frequently updated and you should check for a newer driver.
Feb 02, 2008 | HP Compaq Presario C304NR Notebook
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
