Question about Infogrames Pajama Sam in "No Need To Hide When It's Dark Outside" for Windows, Mac
Program or feature cannot start or run due to incompatibilitywith 64 bit version of windows
How do I fix this? Unsupported 16-Bit Application
You are trying to run a 32bit version program on a 64bit system, this is not allowed. Try obtaining the 64bit version of the program and load that or alternatively try CutePDF, it works well on any system.
Aug 06, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
Apr 01, 2011 | Computer Associates BitWare Plus 4.0 Full...
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have Windows 7. Wanted to install Trophy Bass 2 and get this message. Any suggestions? --------------------------- Unsupported 16-Bit Application --------------------------- The program or feature...
unfortunately no, windows 64 bit doesn't support 32 bit or 16 bit applications so you should call the support number or go online to return the unsupported edition for a 64 bit edition (if they have one). Hope this helps.
Jan 30, 2010 | Computers & Internet
I just bought a new computer that has Windows 7. I try to download my Creatacard Gold3 and am told it is not compatable with a 64 bit driver. Do I throw it out or is there another way to install it?
Two options. Try Googling. Maybe the Creatacard software provider has a 64 bit version of the program available as an upgrade. Many Vista 64 bit programs work OK with Win7.
If this doesn't work and you REALLY need to use THIS program, you can install a 32 bit version of another operating system as a dual-boot. Either XP or Win7 would work. Or run a 32 bit operating system on a virtual machine and run the program on the virtual. That's rather high tech just to run a card maker. So if they don't have a 64 bit version of the program, look for another supplier who does.
64 bit provides faster operations, but it does render a lot of older programs unworkable.
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
Trying to install Math Blaster from ''Knowledge Adventure'' on new vista 64 machine. error on opening setup is ''The program feature ''??E:setup.exe'' cannot start or run due to incompatibity with 64-bit...
Well I do know that "most" 32bit software can be installed on a 64bit windows, unfortunately this one maybe be an exception. I searched all over the maker's websites and could not find a single hint of 64 bit support. One other thing you might try is to right click on setup.exe and run as an administrator , but considering the error you are recieving I don't think it will help. I don't think it is possible, sorry.
Sep 14, 2009 | Computers & Internet
Infogrames Pajama Sam in "No Need To Hide When It's Dark Outside" for Windows, Mac Logo
103 people viewed this question
Top Infogrames Video Game Consoles & Games Experts
newclique
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
EnergeeUK
Level 1 Expert
Are you an Infogrames Video Game Console and Game Expert? Answer questions, earn points and help others
