Question about Home
I have installed a Triton aspirante wireless 9.5 Kw shower. It is just outside of the 2 year warranty and has been used very little. In comparison to the Triton 8.5 KW shower we have in the bathroom it only appears to give the same temperature/flow. When the temperature/flow dial is used it will not react to small adjustment and at times will not adjust at all. Very disappointed with this expensive shower. Any idea as to the cause of the problem?
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 242 Answers
SOURCE: Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Posted on Oct 23, 2008
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
  • 1902 Answers
SOURCE: i have a triton ivory II shower, when the shower
Replace all or just your shower handle seat and washer on the shut off. Seems like a seal has gone bad and is not letting anything seat properly
Posted on Apr 18, 2009
  • 399 Answers
SOURCE: triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Posted on Nov 15, 2009
Triton aspirante shower 9.5kw why is there not much water pressure?
If the mains water pressure is good supplying the shower unit the restriction must be within the unit or the hose and shower head. Try removing the shower head and if no better the unit should be investigated.
Instantaneous shower units are designed for connection to the mains water supply. They can be connected to a header tank supply but a booster pump will probably be needed unless the header tank is at the top of a very tall house.
Nov 21, 2017 | Home
Triton showers say I have to produce a receipt to validate my claim for an engineer to fix my shower,under my garantee which has 4 years to run.this is not so under consumer law,am I right?
buyer without a receipt might be an loop hole
the company lawyers found
Britishcompany huh
you should have paper work of some kind after 4 years
how payment was made
a bank statement or cheque book stub .
large cash withdrawal .something
looks like you purchased an extended warranty ?
Product Guarantee Information
Extended Warranty
if you completed the registration card process after purchase
triton showers should have a record
Register your product
Oct 17, 2016 | Home
I have a problem with my triton shower.i use this shower for 9 months everything was ok but now to get warm water I have to turn the dial to 9 or 10 and it just a little warm and the pressure is very...
Since I am unsure of the model you are using I would suggest you go to their site and check the FAQ's and support information. You can select your info in the drop down boxes and go from there:
FAQ Triton Showers for the Homeowner
I hope this helps.
Jan 29, 2015 | Home
Water is not coming out as fast it has been
possibly your local plumber can figure out the cause . no one can remotely , we do not know your system
Dec 03, 2017 | Home
Water flows continuosly for 1minute after switched off
You need to check all valves, one of them must be broken or too old.
Also the pressure is a little bit higher in there, but there is nothing to be afraid of.
May 05, 2011 | Home
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
My triton shower blew its fuse a couple of times and came back on when I 'flipped the switch' back up. Now it's given up altogether. What's the problem?
Assuming that the circuit and fuse protection you have is correct for the kw rating of shower unit the most likely cause would be an element failure however in order to be more definate relevent electrical checks would be required within the shower unit.
The Triton Service Dept who may be contacted by telephone on 0844 980 0750 would be able to arrange a sevice visit for you where the problem may be investigated further for you.
Oct 05, 2010 | Home
Hi i just installed a triton cara shower and the water wont turn off
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
May 20, 2010 | Home
Shower either runs cold or extremely hot
hi ya, if its a triton shower valve & only 2 years old it should have a 5 year guarantee, ring Triton & arrange a service call.
it sounds as though the filters could be blocked & more than likely the thermostat requires replacing as its more than likely scaled up?
You never mentioned where your based UK or abroad?
Dec 15, 2008 | Home
Home Logo
82 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
