Question about Panasonic DMR-HS2 DVD Recorder
Won't recognise DVD Ram and non-finalised discs from own recordings.
Hi, recently purchased 2 ex-rental discs that were polished in-store. Played one perfectly, then other stalled 1/2 way through. Had trouble ejecting the disc as would take 1-2 mins to come up with U11. Now does not recognise any DVD Ram or non-finalised discs that have played well for years. The other problem it has had for a while is it can continually eject dics (fast!) and stays tray open even when switched off. Only solution so far is to unplug at wall and leave disc in to be re-read once powered up. Are these physical problems (ie dust etc in unit) or software/electrical problems? Any help appreciated as I prefer to keep this unit, it has served me well... Thanks in advance.
  • jaffachef May 24, 2008
    Thanks, Irish Druid. Unfortunately U11 came up again on the screen. I am leaning towards physical contaminants as we have just moved house and had the floors sanded/polished. I did take extreme care to wrap up the dvd, but perhaps we subsequently disturbed more moving the furniture in. If it is not that then I may have to look at replacement parts. I haven't been able to locate parts no.s etc or places to buy. Any ideas? Cheers!
    President:
  • 2,712 Answers
Try updating the firmware and see if this helps:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
Download the software to your PC. Your PC must have a CD-R writer installed. The CD you create must be made using the ISO-9660 format. Using Windows XPs CD writing program is the easiest way to create the Firmware Update CD since ISO-9660 is the default format, so no special settings are necessary. However, other software (such as Nero) can be used, as long as you use the ISO-9660 format. If U11 (DMR-E30/ DMR-HS2) or UNSUPPORT appears on the DVD recorders display during the update process, this indicates that the firmware already installed in your unit is either the same version or a newer version than the one you are trying to install.
Please post back and let me know the results so we can troubleshoot further if that fails.
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson May 25, 2008
    As my colleague Benimur suggested, please try a lens cleaner first.
    You can also try blowing some compressed air on the
    lens. If this and the lens cleaning kit does not work, you should
    remove the cover, access the lens pickup, and clean directly
    with isopropyl alcohol and soft cotton.
    If the lens is scratched or dull, you may need to replace the lens pickup, in which case it may be cheaper to simply buy a new player.
    It is very hard to find new replacement parts for these kind of devices. You can try the manufacturer, although I doubt you will be successful. The other alternative is to look for seconds on eBay and transplant the required parts. (Or if the piece is actually working, might as well use that instead of the defective one!)
    Brigadier General:
  • 6,966 Answers
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
  • Louie  Role
    Louie Role May 24, 2008
    As to your other concern, it would appear to be mechanical in nature and would require cleaning the inside and re-application of appropriate lubricant to the moving parts. A can of compressed air would also help in removing dust and foreign material from the mechanical assembly.
    Additionally, you might find this forum informative if not an interesting read.
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Circular scratches on xbox 360 disc wont work in some areas of game.
The only real solution is to take it to your nearest DVD- Video Rental Store, or store that has a Disk Polishing Machine. The scratches are where the laser head, has scuffed the Disk. Therefore normal Polishing Won,t Work.
The disk needs to be resurfaced.
Mike @ Compurepair.
May 30, 2009 | Microsoft Xbox 360 Console
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Dodgy DVD burner
After completion of recording in the DVD, you have to finalised the DVD then after u can read with other devices
Jun 02, 2008 | LG RH1999H DVD Recorder/HDD Recorder
I want some feedback for DVD Camcorders.
My non-authoritive answers are: 1. Can the DVD-R be played on the Camcorder without finalisation? I'll write no. This is based on one comment by an user plus numerous experiments with DVD+R, DVD+R/W and such formats. 2. Does the DVD-RW / DVD-RAM need a finalisation ? Can the DVD-RW / DVD-RAM be played back on the camcorder/DVD Players/Computers without finalisation ? Based on my experiments with DVD recording and the 3 DVD players I have in the lab, the answers are yes and no in that respective order. 3. Can the DVD-RAM be played in the camcorder and output recorded in a standard VCR Casette ? The media played in the camcorder but placing the media in the VCR doesn't work since it's a phyical media issue. 4. Can the DVD-RAM/DVD-RW be played in the camcorder and the output captured in a computer and then burnt back on the DVD-RAM/DVD-RW or Computer CD/VCD ? Sure, but my method skips the play and re-capture. The files on the media are just placed into the DVD creation software and a new DVD is recorded.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Panasonic DMR-HS2 DVD Recorder Logo
359 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
