Question about Bobcat Equipment Skidsteer Flatbed Car Tractor Trailer
I have a bobcat 843 with an isuzu diesel motor. the fuel system is sucking in the tank acting like a v apor lock. what do i do or where is the fuel tank vent?????????????????
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I added diesel to the hydraulic tank in my bobcat and never an it. I drained the tank, refilled it, and now the hydraulic system wont work.
You should use hydraulic oil, not diesel, drain it, refill it and if necessary bleed all the air from the system (some are self bleeding) Dependant on the type of hydraulic system you may have damaged the seals by using diesel oil, that, unfortunately is expensive.
Mar 05, 2015 | Bobcat 773
Fuel vaporizer system ? Mondeo 2010 where is it to
fuel v apor system is on the fuel tank. There is a carbon filter that filters gas fumes before it is realeased. Gas caps can also throw these codes. Holes in the lines or anything of that nature. Could possibly be the sensor itself bad on top of the tank. Either way, the tank will have to be pulled.
Nov 09, 2014 | Ford Mondeo Cars & Trucks
Bobcat trouble shooting
Hello Angie, Check the fuel filter. Sometimes when the fuel tank is run dry, the sediment on the bottom of the tank gets sucked up by the fuel pump and clogs the fuel filter.
Sep 06, 2014 | Garden
Bobcat 773 wont restart after dying out where do i start?
if the bobcat starts and then runs for a short time then dies the first place to look is the fuel system.fuel filters are the most common problems that i see replace those first.i have also found some junk inside the pickup tube inside the tank.there is probably a ball type hand pump to prime the fuel system.give that a squeeze and see if its hard.if thats the case there shoud be a small screw on top of the fuel filter.loosen that screw and see if fuel comes out when you sqeeze the ball.if your changing fuel filters this is also where you blead air from the system,keep pumping untill there is only fuel and no air.if you still get air after pumping for a long time then your sucking air into the system between the tank and pump.after you get fuel there close the screw,loosen the injector lines going to the injectors,crank the engine,and tighten when fuel comes out (keep clear because that is high pressure fuel).after you get fuel at all injectors and they are all tightened it should start.
May 26, 2014 | Bobcat 773
Isuzu kb 280 dt got a fuel starvation problem after it stands for a few days, when i pump the prime pump on top of fuel filter the problem is gon.
It could either be a fuel pipe between your prime pump and injector pump that sucks air so your diesel flows back into your fuel tank. Or you need to replace the prime pump.There is a rubber diaphragm in the prime pump that gets worn. Unfortunately need to buy a new prime pump. A simple sollution is to fit a non return valve to your fuel line. That need to be connected between the prime pump and fuel tank. Hope it helps. Blessings
Nov 09, 2012 | Isuzu Rodeo Sport Cars & Trucks
I have a 2002 isuzu trooper, my fuel pump is still sucking/filled with water despite changing my fuel filter and draining the gas tank. My radiator also filling with diesel fuel, what could be the culprit,...
To start off with, if you have diesel fuel filling into your radiator you have a serious problem becasue as far as I know all Isuzo Troopers are gasoline powered. Even so, there should be no way for fuel or gas to get in the radiator. I suggest you take it someplace to have it looked at if you have fuel in your radiator. As a matter of fact I would have it towed and stop driving it until you can have it towed someplace.
Jul 04, 2010 | 2002 Isuzu Trooper
Air in fuel
The metal pipes out from the tank rust drop it down and you will see the holes or put fuel hose right over them .
Jun 16, 2009 | 1999 Isuzu Trooper
Bobcat Equipment  Skidsteer Flatbed Car Tractor Trailer Logo
492 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
