Is it possible to search for a specific file that was saved on my toshiba canvio hard drive?
  • 573 Answers
Use this USB Y-Cable.Is it possible to search - f014c47.jpg It provides the extra power you need for your external Hard Disk Drive or other USB devices when a standard USB cable is not able to transfer enough power to operate your device. Simply plug the mini-B cable into your USB A ends into open USB ports on your PC. The cable draws power from both USB ports and increases the output to the external Hard Drive or USB device.
Clue of step are listed below: 8376d83.jpg
Click All files and folders There it will displayIs it possible to search - ad8764d.jpgs formatad8764d.jpg type the name of the file or a document that you are wanted to search. AndIs it possible to search - 480a4b6.jpg option that you wanted to perform.480a4b6.jpgClick Search and see.
All the Best!
Posted on Sep 27, 2010
How do I save files to my Toshiba canvio slim 11 portable external hard drive
you should find someone local to help you out with that, its a little complicated to explain via text. its not a complicated process, there are just a few different ways to do it, depending on how many files you need to back up.
1. find the file you want to copy (this could be a folder, too).
2. right click and select "copy"
3. go to "computer" or "my computer" and double click the toshiba drive.
4. right click and select "paste" and that will copy it.
as i said, there are other ways of copying files, but that's probably the simplest way, although not necessarily the easiest, if you have a lot of files.
Jan 21, 2015 | Toshiba Canvio 500 GB USB 20 Portable...
How do I retrieve my files from Canvio Basics 3.0?
The usual way to back up files is to just open my computer and open the drive that is the external hard disk and just drag and copy the files over. You would then do the same this king to drag the files back to your computer. I am assuming you did not do this and usedsome software that came wwith the drive. In that case I would still open the drive in my computer to see if its there or otherwise u need to use the same software u used to backup the files to recoverthem. If you ccan't figure it out I would redo saving the files the normal way like I explained before . An internal hard drive or even external storage device like USB thumb drive simply shows upas a new drive when plugged in. Do not use an software to save files as usually they are proprietary and use compression which is iinconvenient or makes it difficult to recover
Jul 24, 2014 | Toshiba 1TB CANVIO BASICS EXTERNAL USB 3.0...
I cannot drag files in the Toshiba Canvio Basics 2,0 TB
Please test it by cutting a data file and pasting it in this hard drive. If it is success, then probably the type of your data is different and it is not freely moveable, or you it is possible that you tried to move the files to the same folder (it happens when the user opens many Windows Explorer/File Manager).
Mar 03, 2014 | Toshiba Canvio Computers & Internet
Cannot access my files
Hello, we can't assist you if you are not specific.
which computer are you using? on which system ?
Have you a lot of files on the HDD?
Feb 07, 2014 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
Rename hard drive
Right click on "My Computer" (WinXP) or "Computer" (Windows 7/8) . Click on Manage. In the left window, click Disk Management. In the middle window, right click on the drive that you want to re-name, Click Properties. Above the Type: section there is a box that you can type in. Type in the name of the drive that you want to rename.
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Will the toshiba canvio desktop 3tb hard drive work with the LG 47LM6700 tv?
Depends on the format your hard drives in (personally I'd just use a PC with an HDMI cable) and whether your TV supports USB file reading.
Nov 30, 2013 | Toshiba 3tb Canvio Desktop External Hd
I tried to backup my hard drive from my HP laptop onto my toshiba canvio portable hard drive. The back up failed and now i cannot access the previously saved files on the portale drive. When I plug it...
Try connecting it to the different computer and it is advised to connect it to the back of the computer and run a clean scan on the portable. Right click on the portable hard drive and explore it.
May be you should run the below software to scan your hard drive and computer as well.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Hope this helps.
Cheers!!
Dec 30, 2010 | Toshiba Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
