Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV 48WP30 projection tv bleeding problem
I am getting a red ghosting/bleeding image. If I go to the front and remove the wood panel and turn the red gun off (with one of the 6 buttons), the picture is ok except missing red color.
From what I read on line, this is a convergence problem and it seems that I need to change the IC's.
Where do I purchase these IC and how do I get instructions to do this
Thanks
Yves
yvesq@sympatico.ca
  • Grand Chef May 24, 2008
    Thanks Slinteriors.
    I see that some people use STK 392-150 ICs...what is the
    difference?
    Thanks
  • Anonymous Apr 01, 2009
    i have the same problem with my toshiba..so would you advice mean the same for me??
  • JVC Master
  • 8,617 Answers
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 24, 2008
  • Sonny Berry
    Sonny Berry May 24, 2008
    The STK392-150 ICs run cooler and last longer, they are a little more exspensive but are completely interchangeable the 392-110 are what your set comes with from the factory
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Red horizontal lines
Misaligned red lines in your TV is due to failure of Convergence Out ICs and requires replacement.
Let me know if you are familiar with TV repair to provide you part number info OR call local TV tech to fix the TV.
Thanks.
Apr 18, 2009 | JVC AV-48WP30 48" Rear Projection...
Jvc tv 56 convergence problem
on the 48WP30, you get to the convergence board through the front. Around the back edge of the speaker grille are four screws. You remove these screws. Then you remove the two other screws at the top of the speaker grille near the center panel underneath the front av input door.
THen after you get the speaker grille off, you take the four screws out of the wood panel door and take it off:
Those two big black heat sinks on the front there are your SK chips...on the convergence board of course. pop it up from those four tabs, and that will let you carefully move the convergence board so that you can reach in better, and unhook the three plugs on the right side (looking at it from the heat-sink side) behind the heatsinks (one for red, green, and blue each) and then on the other side of the board, you disconnect the other two plugs, but there's one that you actually have to trace back into the inside of the TV and unplug from a vertical standing board, since the socket is not on the convergence board itself. let me draw up a little graphic real quick.
Hope that helps.
Oct 23, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48 in. Rear... Problem
Your convergence I.C's ( integrated circuits ) Have failed. Replace Both I.C's with Stk392-150's. The unit is equipped with 110's. These are large IC's pn the convergence board located near the front of the unit. You need soldering/desoldering experience to do this job. I would recommend seeking professional assistance.
Jun 04, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Please help me fix my tv
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
Apr 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
179 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
