Question about Craftsman Garden
Blower locked up after about 15 minutes of use. Cord will not pull out as well.
    Scholar:
  • 150 Answers
Check your fuel and make sure you didn't put in straight gas.
Posted on Sep 27, 2010
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
May 04, 2014 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Ran over cord with snow thrower
Can you pull the engine over and then the cord locks or you can't pull the cord at all?
Dec 27, 2012 | Garden
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
Pull cord frozen
if it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
May 19, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
The pull cord on my leaf blower will not move
it sounds as if the blowers engine is locked up. pull the recoil cover off and see if you can turn the flywheel. if you cant the engine is locked and no good.
Oct 26, 2009 | Poulan Featherlite Gas Blower, with Low...
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Weed eater is locked up. can not pull cord at all.
Try taking the cover off around the pull if you can. Likely the cord is not free to spin, or there is a rub on the fly wheel stopping it from moving.
Aug 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Computer is locked in power saving mode and i can not get it out.
I've seen this on laptops, but never on a desktop. Have you totally pulled the power cord and waited around 15 minutes before replacing?
Nov 19, 2008 | HP Computers & Internet
My string will not pull its like its stuck need help thanks
it might have vapor lock, try removing the spark plug and spray a little penetrating oil into the cylinder, let it sit for a couple minutes and try pulling the cord again with the spark plug still off.
Nov 18, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
46 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
