Question about Kenmore Dryers
I have an older model kenmore only numbers I could find was 3389409 everything works except not get any heat. Any help would I would be thankful.
  • Kenmore Master
  • 8,220 Answers
The first thing to do is unplug the dryer. Inspect the vent hose for obstructions.I have an older model - 551550d.jpg
If the element is ok then check the safety's mounted on the heater chamber. 6eb681e.jpgIf all of the safetys and control stats are ok you may have a bad timer. The timer has a fat red wire connected to one terminal. Remove that wire and clamp a lead from an ohm meter there. Check for continuity between that point and other legs of the timer. Turn the timer knob. If you cannot get a reading then the timer contact insideI have an older model - be7ae96.jpgimg src="http://i.fixya.net/uploads/images/be7ae96.jpg" alt="be7ae96.jpg" class="h_mi" /> If that is ok you could have a bad circuit breaI have an older model - 63b213d.jpgtor runs on 120 volts. 63b213d.jpgYou might think you have power to the element but it requires 240 volts. These dryers are worth the trouble and time to repair them. Old school I have an older model - b3842e7.gifl and more repair photos HERE
Helpful?b3842e7.gifRate it or hate it LOL
Posted on Sep 27, 2010
Older kenmore dryer heating problem
its probably either a thermal cut off, thermostat,and or heating element. you need an ohm meter to check each one for resistance and replace whats bad
Apr 23, 2009 | Dryers
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Microwave Ovens
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Dec 30, 2007 | Kenmore 64002 Microwave Oven
Dryers Logo
190 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
