Question about Logitech Z-5500 Computer Speakers
No sound coming out of z-5500
Hey well i setup the logitech z-5500 and there is no sound coming out of any of the speakers. could the sub be blown even the the dock still has power
  • Anonymous Mar 25, 2009
    i have just purchase a set os the z-5500 speakers and havent got any sound out of them since, i have triple checked the cables all in the correct place, and thought my sound card my be playing up so i unhooked it from my laptop and tryed playing music through the speakers from my ipod through the line-in input but no sound, it also continuously says no digial data
    President:
  • 2,712 Answers
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Came home and there was no power to my Logitech z-5500 speakers. Have changed fuse and power cable, still no joy any ideas
i have this same problem, i dno what the heck happend to my speakers. i tries changing the fuse in the plug, and also the timer fuse in the sub itself... stil no fix... im still getting no power to any of the units... the standby light doesnt even come on.
Dec 20, 2010 | Logitech Z-5500 Computer Speakers
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
I have no sound from one of the speakers on my Z-2300 . The speaker itself isn't the problem. I swithced the wires on the back of he sub woofer and both speakers worked when I plugged them into the left...
probably not, seems the output ic or transisters are blown in the right channel. take it to a service shop. also see if under warranty, if you bought it new within the past year. it will be fixed or replaced..good luck...
Nov 13, 2009 | Logitech Z-5500 Computer Speakers
Popping Audio
You may have blown the speaker and need to replace it. Try at a low volume and then at high to notice any difference, if the popping occurs only at higher volume then it needs replacing. I hope this helps
May 27, 2009 | Logitech Z-5500 Computer Speakers
Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
Feb 26, 2009 | Logitech Z-5500 Computer Speakers
Only my sub and rear left and right speakers are working
Come on you guys. You cant run a 5.1 system on a 2,1 sound card. Get you a good ATI 5.1 sound card from Tiger Direct.You get lots of software with the ATI sound card.
Oct 16, 2008 | Logitech Z-5500 Computer Speakers
Woofer popping
Sounds like a loose connection or a blown speaker. I would try just playing around with the wires to see if you can make it pop, if so, the wire you were messing with is the most likely culprit. Also, verify the sub cone has no damage or cracks. I am betting it i a bad connection or a loose wire.
Jul 21, 2008 | Logitech Z-5500 Computer Speakers
Logitech z-5500
Try to click the EFFECT BUTTON a few times to change the effect settings (see also in display) from e.g. Stereo (which uses only two front speakers) to other settings (for which some will use the other (rear/center/sub)speakers as well). Success,
Jun 20, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z 5500
Dennis
First things first:
1) you can buy on audio stores, boxes for 10 inch speakers
then you can do this kind of work,
I try to do what you did, and you know what happend! *&^%$
Open Sky
Feb 10, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
1,124 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
