Question about Whirlpool Refrigerators
I just received my new Whirlpool side-by-side refrigerator with in door water and ice dispensers. How do I connect the water to the refrigerator?
    President:
  • 512 Answers
Connects at back of fridge. bottom left corner you will see a compression fitting, you need to connect to house hookup. If you had it delivered they should have hooked it up for you, unless you don't have a house hookup behind fridge. Then in this case you would need a plumber to run water to fridge. Or you can buy a kit at lowes or homedepot and do it yourself.
Posted on Sep 27, 2010
Whirlpool side by side, water-ice through the door. Icemaker and ice dispenser works fine, water dispenser does not. What could be wrong?
I think the solenoid that operates the water on and off is bad. After awhile calcium deposit builds up around the plunger causing it to stick. That's what happened with my refrigerator. Hope This Helps.
Oct 02, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just bought the Whirlpool 6th sense refrigerator 25.6 cu with water and ice dispenser. However, I am in a place where I cannot connect to water supply because of quality issues. How do I fill in the...
you have to have water pressure to get water and ice you could get a tank and pump to put your drinking water in or get a good filter for your low quality water
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice dispenser not working
RECHECK THE CONNECTIONS AT THE UPPER DOOR HINGE WHERE THE ELECTRICAL WAS DISCONNECTED. MAKE SURE ALL THE PINS ARE STAYING IN THE PLUG WHEN YOU CONNECT THEM TOGETHER.
ALSO, BE SURE THE ICE BIN IS PROPERLY INSTALLED.
Apr 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Ice/Water Dispenser Not Working...
suspect you didnt connect plug and socket wiring at top of door properly
Mar 19, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
