Question about Kenmore Refrigerators
I have a Kenmore Refrigerator: Model Number 106.50254001, Purchased 1-24-2001. It has a water and ice dispenser on the front. I purchased a Rainsoft Water Softening system, with a Reverse Osmosis System for the drinking water. The resulting pressure was not great enough to shut off the valve in the Refrigerator, and so Rainsoft added a pump to increase the pressure to the Frig. However, the pump now "pulses" and creates a pulsing water flow when water is dispensed or the ice maker is filling up with water. Would a new solenoid valve in the frig help, or is there another solution to getting rid of the pulsing? Thanks, Greg K. 740-972-0384
  • Kenmore Master
  • 1,711 Answers
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Posted on Sep 27, 2010
I have just purchased a Samsung 636L Refrigerator and my icemaker doesn't seem to work. Help please.
Hello Roseanna;
My name is Peter. I am a retired field service refrigeration technician.
I require the complete model number to see what you have. The model number is on the wall in the fresh food (refrigerator section)
First, if you have just purchased this unit is it is under warrantee, where a service technician will come to your home at no charge and fix the problem.
I am going to take a guess, having serviced Samsung refrigerators for years, the type icemaker that you have. I believe you may have a ice maker in a small compartment.
Usually a ice maker will start after the temperature is above 40 degrees F. If this is the ice maker I think it is; in the front of the ice maker, on the bottom, there is a small red square button. This is the ice maker cycle button.
Push the cycle button and listen to hear the water fill the icemaker. Hopefully, the installers had just never done this.
Do you have a water dispenser? Is the water dispensing?
If you do not have a water dispenser, then perhaps the installers either did not connect the water line nor turned the water valve to open.
If the ice maker does not cycle, and the water supply is open, chances are you have a bad ice maker.
I have gone on service calls where the unit was delivered one day and I am there the every next day. On these service call I have found bad compressors, bad control boards, and yes - bad ice makers.
Oct 29, 2014 | Refrigerators
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
NO WATER COMING OUT FROM WATER DISPENSER
This could be a bad water valve for dispenser on back of fridge or poor connection in the dispenser control. If you could get me the model number I will be able to help you better. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
268 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
