Question about Riso RZ390 Duplicator
I have a GR 3770; the roller in the machine is raised and won't go down to insert drum.
  • aunderwoo443 Sep 27, 2010
    Thank you! It worked like a charm.
    President:
  • 3,278 Answers
Hello.
From Riso Support:
Reach into the machine and pull the roller up as far as it will go without pulling it out of the cradle. Then, drop the roller. It should go to the right position. It could be a sign that something in the pressure system is malfunctioning, or it could be that the roller just got stuck up. If the problem persists, contact a tech.
Hope this helps.
Posted on Sep 27, 2010
  • NinaE Sep 27, 2010
    You are welcome. Thanks for using FixYa.
Hello we have a RISO GR 3770 - and the cloro drum is stuck in the machine. the green light is not on. how can we get the drum out?
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Apr 05, 2011 | Riso RZ390 Duplicator
We have a riso gr 3770 the drum tray will not
under the drum tray there is a rectangular hole, try to actuate the sensor by flat screw
May 10, 2010 | Riso RZ390 Duplicator
Dispite being on level solid floor the PYE2300AZW has developed a servere vibration. i am over 100 miles from a repair shop so i need to fix it myself. can you offer help
Sounds like your problem may be from flat spots on your drum rollers.
If you have a front loading machine, you would remove the front of the dryer, this will expose the drum. Then you would remove the drum and this will expose the drum rollers. Take a look at them and make sure they look good, while you got the drum out of the way go ahead and lubricate them at the shaft with a good grade of machine oil such as 3 in One oil.
Hope this helps
Oct 01, 2009 | Maytag PYE2300AY Electric Dryer
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Paper Jams
clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at: Salasidis@sch.gr
Feb 25, 2009 | Riso RZ220 Duplicator
Riso GR 3770 master make shadow on it how to fix it?
check the dust or any scar in scanner (glass).
Feb 17, 2009 | Riso RZ220 Duplicator
Riso gr 3770
check sensor (photo) that point towards the drum from inside and clean use a flash light to locate good luck
Dec 02, 2008 | Office Equipment & Supplies
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
297 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
