Question about HP DeskJet 932c InkJet Printer
IWindows 7 OS; HP Deskjet 932c printer; doc's in que; printer will print test page; USB connection to printer; computer does not appear to be communicating with printer. solution to problem???
  • meador_dale Sep 27, 2010
    per suggestions deleted all doc's from queue; disconnected USB to printer; heard USB disconnect alert; restarted computer; heard USB connection alert; attempted printing a doc...doc didn't print...further suggestions??
  • HP Master
  • 4,737 Answers
Is there documents in the Print Queue? if so "Cancel All", you'll need to restart both the printer and the computer to completely delete the print queues.
Can you hear the USB connection alert sound when you plug in the usb cord (while the printer is on)? if so, then it's detected and they are communicating. If not, then try the printer on another computer having different version of windows installed.
Also check the usb cable and make sure it's interfaces are cleaned and cleared. You can try cleaning the terminals with a soft brush dipped in alcohol/acetone/spirit. Get/borrow another usb cable and try.
I hope you already know how to set up the connection: (only for reference)
Let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Posted on Sep 27, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 27, 2010
    Well, now try to update the drivers, first uninstall the currently installed hp drivers/softwares, after it's completed, restart your computer and follow this instructions to update and install the printer's drivers/software (click here), *Click the + sign to expand the tutorials. [Note: this option is available only in Windows 7]. Let me know if this doesn't fix.
    Please try to print a test page from the Printing Preferences.
    Once again Good luck.
Printer wont print
Have you connected both ends of the USB cable ?
Check if you have paused printing on the windows spooler ?
Check if the port is correctly configured on the control panel Install Printer using Windows 7
Aug 12, 2016 | HP DeskJet Office Equipment & Supplies
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
I'm trying to print an article from the computer and blank pages keep running through the printer non-stop.
Try canceling the print job, unplug the printer and plug it back in. Copy the article to a Word Doc. and print it from there.
Dec 07, 2010 | HP DeskJet 932c InkJet Printer
I bought another deskjet 932c from e-bay to replace my old one. I have windows 98se which is not connected to the internet. When plugging in the 932c I just bought, a message comes stating that there is...
Try a self test disconnected from the computer by pressing the 2 left buttons for 4 seconds and then wait for about 15 seconds for a test page to begin. Some models were the right 2 buttons pressed for 4 seconds. If it self test ok then it is software or cable interface. Make sure you are using the same USB or parallel port as before or reset the printer properties to that port. Sometimes the printer dip switches have been messed with and your system will not see the printer properly.
Nov 02, 2010 | HP DeskJet 932c InkJet Printer
The ink icon light is blinking
  1. Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
  2. Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
  3. Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
  4. Select "Setup" on the CD and select "Remove HP DeskJet 932c. The printer software and drivers are removed from your computer.
  5. Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
  6. Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
I have an Hp deskjet 932C and it is printing VERY slow (a page every 6 or 7 minutes). It is also printing only in blue. I have changed both the color and the black ink, and I don't know what to do. Can...
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of each color ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet. Slow printing can be port sharing or software conflicts, so try switching ports or switch from serial LPT1 cable to USB.
Apr 16, 2010 | HP DeskJet 932c InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
It acts likes it's printing, but nothing is on the pages HP Deskjet 932c
Sounds like a defective ink cartridge. See if you have a separate print head you can replace if not sounds like a whole new cartridge.
Assuming you have checked the obvious darkness settings.
Dec 09, 2009 | HP DeskJet 932c InkJet Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Nor printing
Test page is from 4 second 2 buttons press? Or from Windows print window? If you are LPT1 try a USB cable? Perhaps a port conflict or motherboard flaw.
Aug 03, 2008 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
